car only startes sometimes
thanks mike
Corrosion can (and does) work its way up the various connections and will increase resistance to epic levels.
I would clean the battery and starter terminals.
You might have VATS problems. Contacts in your ign tumbler make connection to your key pellet and the VATS module measures the resistance of the pellet and if correct, it closes the start enable relay which passes 12v from the ign sw through the relay through the clutch safety switch and to the starter solenoid on the starter. When it won't crank, wait 6 minutes as the ECM won't allow a crank for 6 minutes when it doesn't see the correct resistance and after several tries. First try your spare ign key as its pellet contacts aren't worn like your everyday key. Next jump the clutch safety switch and try a crank. If no crank remove the hush panel above the drivers feet and locate the two wires from the steering column that go to a 2 pin connector (pellet tumbler contacts). Unplug the connector, insert your ign key and measure the resistance across the wires from the steering column, it should measure the same as your pellet. If over 13k ohms, you need an ign tumbler which has new contacts. You can temporarily bypass VATS by clipping a 5 % 1/4 watt or higher power resistor the same resistance value as your pellet across the wires going into the wiring harness (VATS module). You can use a resistor from Radio Shack. Don't permanently bypass VATS as 99% of thefts are done by bashing the column and jumping the ignition. I am assuming 90's VATS are the same as my 87.
Not many have that kind of expertise.
Most don't have a multi-meter let alone any knowledge on how to use it.
On the VATS is a bad design that only gets worse with age.
By-passing it doesn't take any expertise and it can be done with a kit.
As far as theft goes thats what insurance is for and Corvettes are way down on the steal me list. Japanese imports are on the top.
Plus and this is a real plus insurance compaines pay full dollar if your car is stolen. That is if you can prove you didn't leave the keys in it.
