Broken hood latch
Old Aug 3, 2005 | 10:19 AM
sadieofeden's Avatar
sadieofeden
Default Broken hood latch
I have a 1985 convert. corvette. I tried to open the hood this morning to check the oil. The hood will not open. Is there anyway I can open this hood with-out the latch and cable. Please, any advice?
Thanks, Sadie
Old Aug 3, 2005 | 01:39 PM
Illvtvette's Avatar
Illvtvette
Sadie
Try going to the tool bar ... click on search ... type in hood latch
There's different tips on how to do it along with facts like 'Ecklers' sells a special tool just for this problem
Hope this helps
Good Luck
Tom
Old Aug 3, 2005 | 06:03 PM
sadieofeden
Thanks so much Tom. Have great day
Old Aug 3, 2005 | 08:33 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
If that don't work... look up some of the members in the C4 tech section. This is a common problem that happens over time and they have the tips and tricks to fix.
Old Aug 3, 2005 | 11:00 PM
jabez's Avatar
jabez
Is your hood just stuck or is the cable broken?
Old Aug 5, 2005 | 08:31 AM
sadieofeden
When I pull the latch , it's as if no cable is attached. The hood has alway stuck alittle on one side. But, this is the cable for sure. Any idea's?
To Broken hood latch
