Why does the C4 IRS suck
Old Aug 7, 2005 | 03:39 PM
aboatguy's Avatar
aboatguy
Default Why does the C4 IRS suck
up a lot of HP?
I have been surfing the F-body boards for a few years. I have notice that mods seem to provide F-BODIES a bigger gain than on the Y-BODIES. On the A4s the only major drivetrain difference is the independent rear suspension. What really causes this difference, is it overly optimistic F-body owners?
I am just looking for the real scoop.
Mike
Old Aug 7, 2005 | 04:02 PM
vader86's Avatar
vader86
Solid axles in the F-body and Mustang crowd puts down power better, its a simple geometry and inertia problem. Less twisting or flexing if your axle is one solid piece.
Old Aug 7, 2005 | 04:12 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
This can be minimized somewhat with the proper tweaking in set-up and geometry though. Check with the folks in the drag race section, they ought to have some good ideas. Beam plates will help, modified camber brackets, shocks, etc.
Old Aug 7, 2005 | 04:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Good point.
I have an F-body and it would not hook at all till after I installed subframe connectors to stiffent the body to help weight transfer.
Old Aug 7, 2005 | 04:45 PM
Corvette Kid
Very true, no suspension can can do it's job unless the frame is ridgid, even the C4 can benefit from improvements there. When I first put my current engine package together, traction on street tires was a joke. I couldn't even enjoy the car w/o installing the DRs. Since then, DRM camber brackets, R-Ds Cross Frame have helped a bunch. The Cross Bar has to help too but it was already in place. I plan to install beam plates as soon as I get around to fabbing them. Goodyear F1 Supercars are a damn good biting street tire and I'll give them their credit as well.
Old Aug 7, 2005 | 05:58 PM
ericcer's Avatar
ericcer
I found the beam plates straighten out the 1-2 right side kick. It helped apply the power down.
Old Aug 7, 2005 | 07:03 PM
aboatguy's Avatar
aboatguy
I like the 1-2 right side kick! My D44/3.45 conversion actually made it much more noticable. However, I guess that is a sign of slop in the rear! I installed poly bushings to tighten everything up just a hair.
Old Aug 7, 2005 | 07:43 PM
Corvette Kid
Fish-tailing is impressive but does nothing for improving performance results.
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
The IRS may absorb a little power, after all it does have four more U-joints. But, really, how much power does it take to flex a U-joint? 1/10 hp??
The main problem with drag launches is keeping both tires straight up and down, so the tire contact patch is even. The antiquated live axle excels at this (the only thing it does excel at, except maybe cost), whereas the IRS is best for handling and ride.
I'll take the trade-off any ol' day.
Larry
code5coupe
Old Aug 7, 2005 | 07:51 PM
aboatguy's Avatar
aboatguy
Larry
code5coupe
That is what my question is all about why do C4s seem to take such a big dyno hit?
Old Aug 7, 2005 | 08:03 PM
vader86's Avatar
vader86
inertia and geometry
Old Aug 7, 2005 | 08:43 PM
Corvette Kid
Yes, it's hardly the four extra U-joints that suck up the energy but the suspension dynamics. It was not designed for drag launches.
Old Aug 7, 2005 | 10:07 PM
rocco16's Avatar
rocco16
Who says that they do??
Larry
code5coupe
Old Aug 7, 2005 | 10:31 PM
ericcer's Avatar
ericcer
Larry
code5coupe
Mine did 298rwhp stock. That is what one would expect for a LT4.
Old Aug 8, 2005 | 07:46 AM
Atok's Avatar
Atok
Now I'm not a drag racer but I'll take an IRS car over a solid axle anyday. There are many advantages to IRS for overall performance. Also, I'm not so sure the F-Body launches better than a C4 from what I've seen.
Old Aug 8, 2005 | 09:54 AM
rocco16's Avatar
rocco16
Perhaps thats because the Y-body makes more power to start with from the same engine, so the F-body has more potential...more room, so to speak...before it reaches parity with the Y-body??
Sounds like the original question is this: will the same modification (K&N, say) gain more on an LT1 Camaro than on an LT1 Corvette?
Perhaps it will, since the Camaro is usually rated less to begin with.
That said....I can only ask another question: so what?
Larry
code5coupe
Old Aug 8, 2005 | 12:36 PM
redwing76's Avatar
redwing76
Larry
code5coupe
So what,
To Why does the C4 IRS suck
Old Aug 8, 2005 | 01:14 PM
Nathan Plemons's Avatar
Nathan Plemons
My experience has been that the C4 vettes and f-bodies with the same kind of drivetrain always dyno approximately the same in the HP department. The fact that the Vette was rated higher HP is simply marketing. The f-body engines made just as much HP, they are just placed in a heavier body. They're rated less so that the Corvette will still be the king of the hill.
Old Aug 8, 2005 | 02:18 PM
65Z01's Avatar
65Z01
And too look at the entire drive train, that is what were the grears in the two cars that started this discussion??
Indeed my 3rd gen Camaro is about 300lbs heavier than my C4 so, with the same drive line, the C4 will launch harder..it's the physics not the IRS.
Old Aug 9, 2005 | 12:38 AM
mitymek's Avatar
mitymek
marketing ploy? wow thats a new one.
so the f-body lt-1 engines are the same as the corvette lt-1 engine?
i thought the vette motors were better from the oil pan up.4 bolt mains,different crank number,different rods,different pistons,different cam,different heads and so on and so on.
so your saying the actual gm part #s for the above mentioned parts are the same betweem f-bodys and y-bodys?
got me wondering now.seriously.
an arcticle i read on the new mustang gt's stated they considered irs for it but opted for the straight axle for 2 reasons,1 being less parasitic draw from straight line acceleration and 2 (and mainly) being cost.
of all the cars ive owned over the years (im 48)ive never had one that hooks up (stock) like the vette does.the suspension just squats and hooks.
how many basically stock cars do you see picking up the front tire?(check some of mojo's shots)
it may cost a few ponies but i say add some elsewhere and enjoy the bennys of the irs.
