Jacking question
Old Aug 10, 2005 | 08:22 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
Default Jacking question
What is the best location to place jack stand on the rear of an 86 coupe.
Old Aug 10, 2005 | 09:07 PM
Wayne88's Avatar
Wayne88
Along the bottom of the car,
you will see a plastic strip with 'jacking point' printed on it.
In back of this plastic is the frame.
Get down and look at the configuration of the frame.
I've used almost every point of the frame for jacking.
Old Aug 11, 2005 | 08:34 AM
runner140*'s Avatar
runner140*
This question comes up seems at least once a week. Your explanation is exactly the only answer. Good post.
Old Aug 11, 2005 | 12:06 PM
aboatguy's Avatar
aboatguy
However, it also depends on what your trying to do? I have also used suspension pieces as jacking points. Just use common send and only use beefy (strong) areas as lifting points. I had to lift using the spring ends during my rear end swap ( however, I used padding so to protect the spring).
Mike
Old Aug 11, 2005 | 12:51 PM
bizaro's Avatar
bizaro
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
opps, thought this was something else, nevermind.
Old Aug 11, 2005 | 01:16 PM
jrp's Avatar
jrp
If you look just in front of the wheel well, where the frame bends inboard, you'll see a pocket in the frame just the perfect size for your jackstand. Similar story behinds the front wheels. I put my floorjack near the labelled jacking points, and my stands in those pockets. I should take pictures the next time I have it up.
To Jacking question
