Changing coolant: Anything special procedurewise??
I'm heading out in a little bit to have my coolant changed. I'm dubious about the shop that will be doing the work on Vettes, but I can be at their side supervising while they do the work. Anything special I should know about?
I would do it myself. It's seriously not hard. And if you have a Shop-Vac with blower capability, you don't even have to remove the knock sensors to get all the coolant out.
In my 86' I have to "pack" the radiator to keep the "low coolant" light from coming on.
Here is what I do after I have finished the initial coolant fill with the motor off:
1) Start the cold motor with the radiator cap off.
2) Add coolant as necessary as the temp comes up.
3) When the thermostat opens, have a second person bring the motor up to 2,000RPM. The coolant level will drop significantly.
4) Top off the radiator and replace the cap while the motor is being held at 2,000RPM.
P.S. - I also usually have the car up on ramps so the radiator is at a higher than normal point reletive to the engine.
It's a simple procedure and the shop vac works great for getting all the liquid out. I just hooked my shop vac hose up to the exhaust port of the shop vac and then placed the end of the hose over the radiatior fill hole. It forced the coolant out of the lower radiator hose which I had removed from the radiator side.
