remote start on 6 speed?
Old Aug 16, 2005 | 11:51 AM
cjg454ss's Avatar
cjg454ss
Default remote start on 6 speed?
is there any way to get a remote start on a 6 speed. besides the fact that you could always have to keep in in neutral and the parking break on.
Old Aug 16, 2005 | 12:06 PM
Aaron71771's Avatar
Aaron71771
You would have to bypass the clutch safty switch, then the rest should be fairly easy. An ideal remote start device would detect if the car is in fact in neutral or not.
Old Aug 16, 2005 | 12:26 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I fail to see the reason for installing a remote starter.
Can anyone enlighten me?
Larry
code5coupe
Old Aug 16, 2005 | 12:34 PM
bizaro's Avatar
bizaro
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I have one in my daily driver, allows me to heat the car up in the winter before leaving for work. Also handy on hot days to cool the car off with air before entering. I use it alot. I hate getting into a cold car in the morning. Even if it is in the garage it gets mighty cold in these parts. Have you been enlightened?
Old Aug 16, 2005 | 12:38 PM
Nathan Plemons's Avatar
Nathan Plemons
My aftermarket alarm / keyless entry came with a remote start so why not install it?
It is wired through the parking brake so it won't start unless the parking brake is on. It bypasses the clutch safety switch when the remote start is used, otherwise it works normally. Unfortunately I have not found a good way to detect if the car is in neutral or not so I just always leave it parked in neutral with the parking brake on. That actually works since my Vette parking brake actually works. Wouldn't work so good on some vehicles I've driven.
Old Aug 16, 2005 | 01:08 PM
rocco16's Avatar
rocco16
The remote starts the engine, does it also turn the climate control on?
Can you choose between heat and A/C on the remote fob?
('d like to have my car cooled down before I open the door, too...)
Larry
code5coupe
Old Aug 16, 2005 | 01:20 PM
JCD's Avatar
JCD
Sorry Larry, I think you have to plan ahead to get that feature.
Old Aug 16, 2005 | 01:21 PM
cjg454ss's Avatar
cjg454ss
Larry
code5coupe
no you have to have the ac/heat set where u want when you shut if off so when it starts it goes back to the last setting. i just want to to cool of the car in the summer here in florida and to let the motor warm up a couple mins before i get in it and go
Old Aug 16, 2005 | 01:38 PM
rocco16's Avatar
rocco16
I see. I guess it won't work on mine; the electronic climate control always defaults to OFF when I shut the ignition off...I have to turn the ECC to ON (by pushing buttons) after I start the car.
Oh, well...I guess I'll keep doing it the old way. Thanks!
Larry
code5coupe
Old Aug 16, 2005 | 01:59 PM
HURRICANES99's Avatar
HURRICANES99
nothing like running a car in a garage....great healthy fumes
Old Aug 16, 2005 | 02:41 PM
Nathan Plemons
Larry
code5coupe
Maybe maybe not, it depends on what you're wanting. Are you wanting to cool the car down in the summer or warm it up in the winter?
If you're wanting to cool it down, you're right you're completely hosed
If you want to warm it up though there could be some benefit. Although the heater wouldn't be actively heating the cabin the engine could still be warming up so that when you get to the car you actually have some heat when you get in the car and turn on the heater or defroster.
Old Aug 16, 2005 | 06:01 PM
Saisling's Avatar
Saisling
St. Jude Donor '05
I had given some thought about putting one on my wife's 5spd Mustang GT, but knowing the track record for Ford parking brakes and the fact that our driveway is a steep downward incline, I've talked myself out of it.
Old Aug 16, 2005 | 06:49 PM
c4cruiser's Avatar
c4cruiser
Larry
code5coupe
Guess in the wintertime, it helps to get the car running so the heater works when you go out to drive away.
But there is a down side to comfort like that. In Tacoma, WA the city passed an ordinance making it illegal to leave a car unattended with the engine running. Last winter the rate of car thefts were up substantially because people went outside to start their cars then run back in to wait for the engine to warm up. Car thives would cruise neighborhoods looking for cars that were running and nobody in them. They would simply open the door and drive away.
The city PD had cruisers out in neighborhoods looking for the telltale sign of condensation from exhaust pipes and empty cars and the officers would go up to the house, knock on the door with their citation books in hand. The fine was pretty stiff, over $200!
Old Aug 16, 2005 | 09:16 PM
DVNCI's Avatar
DVNCI
I've got a Clifford AvantGuard alarm and it has remote start. I don't use it much but it is pretty cool . . .
Old Aug 16, 2005 | 09:28 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
Larry
code5coupe
That's odd, what year's your LT1? I usually turn off everything before shutting my car off. But If I forget, my climate control's always set and running wherever is was set at before. Mine's a '95.
To remote start on 6 speed?
