Speed Bleeder Leaks
Old Aug 19, 2005 | 12:51 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Speed Bleeder Leaks
Hey guys:
Just redid my brakes, new pads/calipers, SS Lines and Speed bleeders and major power flush, really amazing the color change (brown to clear), anyway. Everything is great, except that I'm getting some leaking from the open tip of the bleeder. I've tighted down the bleeder to torq specs, but still some drips... Any ideas. vinnies87
Old Aug 19, 2005 | 01:13 PM
F1Fan's Avatar
F1Fan
I know theres alotta guys who like these things, I've had two different brands of them, and they are back sitting on the shelf in the garage.
My biggest peeve with them is that they can suck air back in around the threads when the pedal comes up, and I know to only have them open enough to do the job. Granted, it's probably a small amount, but still. I've gone back to the two person method.
I wonder if yours could be bottoming out in the caliper though. Make sure you got the right length. What brand are you using?
Oh, I love the plate in your avatar!
Old Aug 19, 2005 | 01:56 PM
luvmy92's Avatar
luvmy92
Were either of yours Speed Bleeders?
http://www.speedbleeder.com/
just curious...
Mike
Old Aug 19, 2005 | 02:17 PM
F1Fan's Avatar
F1Fan
I don't think mine were, those seem to have a hole before the bottom for the brake fluid to come out, and both of my sets had the hole at the very bottom, otherwise they look the same. One set was from JEGS, but I can't recall where I got the other set from...
Old Aug 19, 2005 | 03:06 PM
vinnies87's Avatar
vinnies87
Got mine from Corvette Central... Yea, maybe back to the old style.. and rebleed the system. oh well, at least it wasn't a major expense.
Old Aug 19, 2005 | 09:56 PM
c4cruiser's Avatar
c4cruiser
If the bleeders wee new at the time of install, it might be due to some material left in the threaded holes in the calipers. I would pull the bleeders and chase the threads to clean them out and re-install the Bleeders.
If you had the bleeders in the other set of calipers, it may be due to the sealant that was applied to the bleeders has lost its effectiveness. IIRC, Speed Bleeder recommends that the sealant be re-applied after about a dozen or so loosening/tighten sequences. You can get the sealant material from the Speed Bleeder website.
If you had the Russell bleeders, those are not near the quality of the original Speed Bleeders.
Old Aug 19, 2005 | 10:22 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The russell "sealant" crap was rock hard. Left chunks in my caliper and I nearly stripped the threads tightening them.
Run them all through a thread die to remove the sealand, and put some teflon tape on them instead. That'll keep air from getting sucked in.
Old Aug 19, 2005 | 10:59 PM
vinnies87's Avatar
vinnies87
Thanks bud: That sound like a much better idea, "Teflon Tape & Thread Die". You know, that means i have to remove the wheels again, let see, that makes 4 times now on 1 complete set (4) brake job. Better that than leaks...
Old Aug 19, 2005 | 11:05 PM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Hey Vinnie,
sounds like you have this under control.
I just stopped in to say hi. Good to see ya.
Old Aug 19, 2005 | 11:11 PM
vinnies87's Avatar
vinnies87
Originally Posted by longhorn_C4
Hey Vinnie,
Hey Bud... glad you stopped by... Yea... Hope that works, if not, its back to the origional bleeders. Seems funny tho that its leaking out of the top hole, like the ball stop or spring in the bleeder is bad, ok well.
To Speed Bleeder Leaks
By Michael S. Palmer | 2026-06-03 11:00:24
