Antenna won't work...
Old Aug 23, 2005 | 12:33 PM
ken93vette's Avatar
ken93vette
Default Antenna won't work...
I recently purchased a 93 vette.
The bose system was not fuctional so I had a Sony system installed. The antennal hasn't worked, motor doesn't even make noise. Is the motor dead and needs replacing or is there another test to make sure it is getting power?
Old Aug 23, 2005 | 12:34 PM
bogus's Avatar
bogus
You need a copy of the factory service manual... go to www.helminc.com!
Also, there are tests, but hell if I remember the wire colours.
The Helm Manual will show all relevant information.
Old Aug 23, 2005 | 12:56 PM
newbecorvetteguy's Avatar
newbecorvetteguy
When I got my car, the antenna was unplugged at the relay under the trim in the vacinity of the hatch latch. The ribbon was broken in the antenna so the motor would run all the time if plugged in. Check the fuses, check the connector at the relay. Also determine if your new radio has a wire to accommodate a power antenna. Not all do. If it doesn't you'll have to either install a switch to power it up, or hook the wire to a circuit that is hot when the key is on. If done that way the antenna will go up when the key is on, down when the key is off.
Old Aug 23, 2005 | 01:05 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Not Being A Expert, When I Had My Radio Replaced I Had To Mention The To The Installer That They Have To Wire The Antenna To The Radio To Make It Work. So After He Connected Properly My Unit When I Hit Cd Player The Antenna Goes Down. Check With The Person That Installed To Make Sure He Connected The Antenna Wires.
Old Aug 24, 2005 | 01:18 PM
mseven's Avatar
mseven
The bose system was not fuctional so I had a Sony system installed. The antennal hasn't worked, motor doesn't even make noise. Is the motor dead and needs replacing or is there another test to make sure it is getting power?Thanks
IMO
There is a real good chance thet it isn't even wired in let alone antenna lead connected. Check all fuses first it should run through at 2-3 incl. courtesy.
The reason I'm mentioning this next is because this is what I found!
I would pull radio out and check if the purple lead from back of radio (if I remember correctly) is connected to a pink lead wire and check if the antenna coax itself is plugged in to the radio.
From there I would check for power at the relay, under panel at rear hatch by the latching mechanism.The manual tells you which wire is hot w/test light w/ ign. on and off.
I would look at all this first before buying an antenna assy. Let us know what you find
To Antenna won't work...
