Another Question
Old Aug 27, 2005 | 03:10 PM
Buttz's Avatar
Buttz
Default Another Question
Im new to the vette world so Im asking a million questions. My 87 starts ruff, it fires right up it just idles ruff. I changed the plugs and wires but it didnt help much.Once it warms up it smooths out and runs great. Any ideas?
Old Aug 27, 2005 | 03:14 PM
Jet-Jock's Avatar
Jet-Jock
Clean your throttle body and if necessary the IAC valve. Just test the results by opening the butterfly's and giving it a good spray of Throttle Body cleaner. Don't loose the plastic straw. If its real nasty in there back side of plates probably need to remove it and give it a good cleaning. Order new gaskets before hand.
Old Aug 27, 2005 | 05:26 PM
czissman's Avatar
czissman
How many miles?
Does it smoke at all when you start it?
I'm no pro, but I'd do a compression check and look for consistency across all cylinders. I'd also put a vaccuum guage on and look for a steady needle, probably in the 20" range at idle. Might give you an idea of the conditions in your motor. I'm sure others will correct add more about compression and vaccuum readings.
Old Aug 28, 2005 | 02:49 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
It sounds like the intake just needs a good cleaning.
If you pull the IAC motor to clean the pintel and it's bore under the TB, there is a method on my site to set base idle and the TPS voltages.
Are you getting any stored trouble codes??
Old Aug 29, 2005 | 09:18 PM
Buttz's Avatar
Buttz
Im gonna take the throttle body off and clean her up but for reference its a 87 with 113,000 of my grandpa's miles. thanks again guys
Old Aug 29, 2005 | 09:44 PM
Casethecorvetteman's Avatar
Casethecorvetteman
If you get a puff of smoke on start up, and it hesitates when cold, valve guide seals are the most likley culprit there, quite a common thing.
To Another Question
