higher stall converter users help needed
Old Aug 30, 2005 | 06:22 PM
JAYK's Avatar
JAYK
Default higher stall converter users help needed
All you guys using them,do you run an aftermarket transmission cooler.If so where have you got it mounted.Pics please
Old Aug 30, 2005 | 06:32 PM
AFogleman's Avatar
AFogleman
A tranny cooler is mandatory!Unless you want to buy another pretty quick.Mine is mounted right in the middle of my radiator in the front.A higher stall creates more heat,and heat kills trannies!Someone will explain it better I'm sure!!!
Old Aug 30, 2005 | 06:56 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Not a good pic, but the only one I have handy.
Old Aug 30, 2005 | 07:00 PM
JAYK's Avatar
JAYK
which make converter are you all using,which is the best?
Old Aug 30, 2005 | 07:08 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I researched this a lot when I wanted to up my stall...the big three, Precision, Yank and TCI all agreed that a stall under 3000 did NOT need a stand alone tranny cooler...I'm running a TCI 2400 stall with no cooler and no problems for the past 18 months...
I suppose if you go to a 2800 you could put one in to be extra safe...
Old Aug 30, 2005 | 07:56 PM
Admrl94's Avatar
Admrl94
I suppose this would be a good time to ask: can someone please educate me as to what a stall converter is, what it does, and how it would work on an automatic?
Old Aug 30, 2005 | 08:07 PM
JAYK's Avatar
JAYK
One more question,will changeing the stall speed require the computer to be reprogrammed?
To higher stall converter users help needed
