outside temp and temp control problems
Old Sep 4, 2005 | 09:42 AM
07blkvette's Avatar
07blkvette
Default outside temp and temp control problems
had the 95 vet out yesterday and hit a big pothole and my outside temp went from82 to 20 and when i checked the temp control it was reading 15. any suggestions what might of happened. thanks
Old Sep 4, 2005 | 11:48 AM
Red Dwarf's Avatar
Red Dwarf
The temp sensor is located on the front right of the radiator. You can get to it pretty easily. Probably just a loose connection??
Old Sep 4, 2005 | 12:24 PM
PsychoNumber1's Avatar
PsychoNumber1
From: Behind The Redwood Curtain, The State of Jefferson
obviously!... That pot hole was a worm hole and you've been thrown into an evil parallel dimension where the U.S. has gone... *gulp* METRIC!
To outside temp and temp control problems
