Good deal?
Old Sep 4, 2005 | 09:57 AM
Rev's Avatar
Rev
Default Good deal?
Well, yesterday I went to look at a 1996 Vette. It has a 6 speed and lt4. It has 84,000 miles.There were misc. scratches and chips here and there, not too bad. The left seat is torn. It needs a new throwout bearing (makes a growling noise when you let off the clutch). Targa top looks like it needed to be painted or something. Also looked like it needed new weatherstripping in areas. Oh and one more thing the e-brake sticks when its pulled up (any solutions to that problem?) They were asking 11k, I talked him to 10k and left a deposit. What do you guys think? Thanks
1G1YY2255T5105374 Here's the vin if anyone can run it and tell me all the options it has or something?
Old Sep 4, 2005 | 10:16 AM
redvette6spd's Avatar
redvette6spd
Car sounds like a 6 out if 10. 10k sound's like a fair price. If you do your own work even better. Is this the car that is listed in the for sale section of this forum if so someone did a car fax on it and it came up as a salvaged title. That would make a difference
Old Sep 4, 2005 | 10:19 AM
Rev's Avatar
Rev
Nope, not the one in the for sale section.
Old Sep 4, 2005 | 11:12 AM
cv67's Avatar
cv67
St. Jude Donor '05
10k doesn't sound bad at all!
Old Sep 4, 2005 | 03:57 PM
Midnite 88's Avatar
Midnite 88
You say the E-brake sticks when you pull it up? Well, the E-brake should engage when you pull up on the handle. You can just push back down on the handle so you can get out of the car.
If you want to release the E-brake you pull back up on the handle and push and hold the button on the end of the handle and lower the handle while still holding the button.
Is it doing something other than what I described?
Old Sep 4, 2005 | 05:09 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Ya done good. A little work and $ and you will have a great car!
Old Sep 4, 2005 | 06:28 PM
Rev's Avatar
Rev
Lol, sorry I should have described it better. When you try to disengage the e-brake it is very hard to get it to go down.
Old Sep 4, 2005 | 06:45 PM
Rev's Avatar
Rev
Also, is there any way to make sure that the growling noise is a throwout bearing? It makes the growling noise when it's sitting there and when you start off when the clutch is let out. I'm just wondering if maybe this is a common problem on vettes or if it could be potentially something worse?
Old Sep 5, 2005 | 12:58 PM
Rev's Avatar
Rev
Anyone know anything about the bearing?
Old Sep 5, 2005 | 01:33 PM
Zidane's Avatar
Zidane
Cruise-In VI Veteran
Sounds like a good deal.
Old Sep 5, 2005 | 01:43 PM
joe3906's Avatar
joe3906
10k is a lot of money. However, if your happy with the numbers go for it. Personally, I would shop around and consider other cars that have less mileage and less wear and tear, but that's the way I do business. I would prefer to spend a couple of dollars more, and pick up something with a tad less mileage, and as little problems as possible to deal with once I purchase the car. Guessing at what the cause of a noise in a car is not what I call a selling point. My .02.
Joe B.
Old Sep 5, 2005 | 02:07 PM
petdoc's Avatar
petdoc
Default Growling noise
Hey Rev...If I understand it correctly, the throw-out bearing noise(when it's going south) is heard when you have the clutch pedal on the floor. If the noise is heard with no pressure on the clutch pedal, then it is most likely the input shaft of the transmission. Most of the 6-speeds do the latter, from a faint whine to a pretty good growl like my car does. Most say it is not a problem, but it's disturbing none-the-less. Good luck!
Old Sep 5, 2005 | 02:49 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
A release bearing would not be prone to changes in acceleration/deceleration. Sounds about right for the money, enjoy!
Old Sep 5, 2005 | 04:37 PM
Strick's Avatar
Strick
Just a thought, is it possible the previous owner installed a single mass flywheel? That would produce a growling (box of rocks) sound.
Put her up on a lift and have a look before you sign the deal.
Old Sep 5, 2005 | 05:33 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
I was getting a growling noise from the Muncie 4 speed in my 69 when the clutch was let out (most noticable in neutral). It was the input shaft bearing and eventually the trans had to be rebuilt as every gear was missing teeth. I suggest you have someone with a good knowledge of ZF's check it out as they are a lot more expensive the the M20.
Old Sep 5, 2005 | 05:57 PM
Aquaman92's Avatar
Aquaman92
If the throwout bearing I wonder about the clutch and flywheel.
Old Sep 5, 2005 | 06:16 PM
myvettesblue's Avatar
myvettesblue
St. Jude Donor '05
sounds like a good deal if you can do most of the work yourself other than that you would have a fortune in it
To Good deal?
Old Sep 5, 2005 | 06:48 PM
SLOWRIDE's Avatar
SLOWRIDE
It is a good deal. You could part it out for more than that.
Old Sep 5, 2005 | 08:25 PM
Rev's Avatar
Rev
Well, the transmission seems to shift perfectly fine and the clutch doesn't slip at all.
Thanks for all the replies guys. I'm still deciding on it, now that transmission thing has got me worried.
Old Sep 5, 2005 | 11:26 PM
Perfusion's Avatar
Perfusion
$10k for the car sounds like a steal... Nice find.
