Oil cooler
Old Sep 9, 2005 | 08:17 PM
Pete K's Avatar
Pete K
Originally Posted by mb87
Its located on the cooler.
What is?
Old Sep 9, 2005 | 08:32 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
He means the oil temp sw is located in the oil cooler; on cars w/o the cooler it is in the block above the oil filter.
Check the resistance of the oil temp sw when cold and then when warm or hot. The resistance should drop as temp goes up.
It sounds like you have a problem with the wiring or digi dash, as mentioned. Before sending out the dash for service I would wring out the wire between the oil temp sw and the digi dash.
Old Sep 9, 2005 | 08:56 PM
Pete K's Avatar
Pete K
That is what I thought he meant. My 87 has no provision in the cooler for anything. The sensor is in the block above the cooler/filter.
