Repainting Targa top
Old Sep 9, 2005 | 11:01 AM
dwestsr's Avatar
dwestsr
Default Repainting Targa top
I want to repaint my targatop on my 86 coupe. It looks like there is a moulding around the perimeter. How do you get this off and what do you use to put it back on? Can I replace this moulding or do I have to salvage the old piece? I would rather do the sanding and repaint with the moulding off in order to make it look original. Thanks
Old Sep 9, 2005 | 06:58 PM
96_LT1's Avatar
96_LT1
Ive got a similar thread going here, check it out.
Here
Old Sep 9, 2005 | 08:42 PM
Riks40th's Avatar
Riks40th
From: St. Louis, Mo......... 1993 Torch Red w/White Interior...2006-07 Bloomington Gold 2005-ZR1/C4 Gathering, 2001-2012 Funfest
Yes, you definitely want to pull this trim off before painting. If the trim is in good/great condition you can reuse it. Try to pry the trim off from the underside corner. I used a very small screwdriver to pry mine off. Once you get it to move it will come right off. When putting it back on, I would recommend you let the paint cure for about a week before putting it back on. This is what my paint shop recommended to me when I had mine painted. When I re-installed the trim, I just worked it all the way on slowly by hand to make sure I didn't damage the new paint. Once it is all the way on it will not come off.
Good Luck
Rik
http://photobucket.com/albums/y126/Riks40th/
To Repainting Targa top
