Engine cleaning question
Old Sep 10, 2005 | 07:45 PM
87 rag's Avatar
87 rag
Default Engine cleaning question
My L98 doesn't look as clean or new as I would like it to.
I think a past owner sprayed it with some sort of clear coat or something that is now old yellow and flaking off. It is on the plennum, runners hoses, you name it.
Does anyone know if a product that I can try spraying on and hosing off that should restore some newness to the look of the engine?
I don't like the idea mutch of tearing it down and polishing each piece by hand but I don't want to leave it the way it is either.
Thanks in advance
Old Sep 10, 2005 | 07:57 PM
95Torch's Avatar
95Torch
Simple green works great, and can be found at most auto parts stores. Spray it on while the engine is warm, hose down. Most of the top layer of oil and gunk should come right off. For the subborn and hard to reach areas I use a toilet bowl brush...it seems to work well. Also make sure and cover you distributor or opti-spark, otherwise you could have problems starting it back up.
Old Sep 10, 2005 | 08:01 PM
87 rag's Avatar
87 rag
I'll look for simple green.
No opti in the 87 but I'll cover the distributor. Anything else that doesn't like to get wet?
I'm jealous of your engine bay.
Old Sep 10, 2005 | 09:25 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I'd be careful of the dist as well as any weather packs that are not really tight.
Old Sep 10, 2005 | 09:28 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
My 87 was pretty nasty too. I used Simple Green and some brushes. I also repainted the plenum and valve covers with paint from Corvette Central. Nothing fancy but it looks a whole lot better than when I bought it.
Old Sep 10, 2005 | 09:49 PM
myvettesblue's Avatar
myvettesblue
St. Jude Donor '05
looks good ron though simple green works well i personally use purple power which also works real well also works to cleanyour carpet and wheel wells
Old Sep 10, 2005 | 10:07 PM
daddog's Avatar
daddog
St. Jude Donor '15
Default water=bad air=ok
Thanks in advance
i am skeereed of using water on my motor (174k never touched) so i use air with a long "snozzle" and brake cleaner.......if you really want to use water and a motor cleaning product, i would say wait till the motor is not going to be needed for a day or two and then spray the cleaner on being careful not to get it on anything electric or on your paint areas......then water spray it off 1/2 hour later , still NOT spraying on any thing electric and pour water on the painted parts that that you did not mean to involve in this process, but did. the next part is the most important......DONT start the engine untill at least the next day...
if you have compressed air dry everything as much as you can. hope this helps i have been where you are going and want to save a brother some agony.
Old Sep 11, 2005 | 08:55 AM
87 rag's Avatar
87 rag
All good advice.
I'll watch for the purple as well.
Nice looking engine Ron. Don't tell me you left it all together to make it look like that.
Am I the only one with a dirty engine?
Toilet brush shounds like it would work.
To Engine cleaning question
