RPO Code for 6 Speed
Old Sep 16, 2005 | 10:05 AM
GSjimbo's Avatar
GSjimbo
Default RPO Code for 6 Speed
I have a '96 LT-4 Grand Sport . I was checking the RPO codes on another GS today and noticed two differend RPO codes for the 6 speed trans.
ML9 - Transmission, Manual 6 Speed ZF (mine)
MN6 - Merchandised Transmission, Manual 6 Speed (the other GS)
Does anyone know what the difference is?
PS Would have asked on the GSR but forgot my password!
Old Sep 16, 2005 | 10:18 AM
jwt1603's Avatar
jwt1603
Below are the RPO codes used typically used for transmissions. You sure yours isn't ML9?
* M30 - Automatic 4-speed electronic transmission
* MD8 - Automatic 4-speed transmission
* MK2 - Manual 4-speed Doug Nash transmission
* ML9 - Manual 6-speed, ZF-transmission
* MM0 - Automatic transmission
* MM4 - 4-speed manual transmission
* MN6 - 6-speed manual transmission
* MX0 - Automatic transmission
* MY6 - Manual 4-speed transmission
Old Sep 16, 2005 | 10:41 AM
GSjimbo's Avatar
GSjimbo
Actually you're partially correct. The ZF which I have is RPO ML9. I corrected the original post). The other ones RPO is shown as MN6?
Old Sep 16, 2005 | 10:57 AM
jwt1603's Avatar
jwt1603
GM had (has?) a tendency to have variations in the codes they used. At the top of this section is a sticky that lists all of the codes. Every once in a while new ones are added. Browse that and you'll see that there are a lot of different codes from year to year for the same option. Sometimes the codes changed inside a model year.
Old Sep 16, 2005 | 09:52 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
ML9 = ZF 6-speed manual transmission
MN6 = provisions for manual transmission
Old Sep 18, 2005 | 09:36 PM
Atok's Avatar
Atok
My '95s RPO sheet lists both ML9 and MN6.
Old Sep 19, 2005 | 05:25 PM
LilR3dCorvette's Avatar
LilR3dCorvette
St: Jude Donor '10
Same for my '89...both ML9 and MN6 listed.
To RPO Code for 6 Speed
