Winterizing my 95'
Old Sep 22, 2005 | 10:50 AM
corvette8n's Avatar
corvette8n
6th Gear
Default Winterizing my 95'
Does anyone have links on how to prepare a C4
to be stored for the winter. Some have told me to fill tank and put in Sta-bil other have said to run it as empty as I can get it. I want to also jack it up and put it in jack stands where should I position them. Any other hints would be appreciated. I don't think my car would go to well in 24 inches of snow, that why I also
have a 4wd truck.
Old Sep 22, 2005 | 11:53 AM
n1kki6's Avatar
n1kki6
I dont do crap, its only sitting for four months. I fill the tank and put in gas stable, that all. Been doing it for three years and my car still runs perfect. Mine gets parked under our deck with a car cover.
Old Sep 22, 2005 | 12:16 PM
bills1985corvette's Avatar
bills1985corvette
I jack it up an put a jack stand at each of the 4 jacking points identified by the two small arrows. I put a small screw jack under the main cross member in the front. I hook up a battery tender. I cover the car and wait for spring. Gas should be fine.
Old Sep 22, 2005 | 01:04 PM
84number2083's Avatar
84number2083
I have had my Vette for 18 winters, which equates to roughly 3,600 inches of snow in these parts. It has spent most winters in an unheated garage with absolutely no special treatment except unhooking the battery and a car cover. It spent 2 nasty winters outside with a car cover and I had to shovel it off from time to time (carefully). Most winters, but not all, I have started it up and let it run for a while about once a month. In the spring I fire her up and go for a ride....the tires feel a little square for a couple miles then the engine settles in and purrs like a kitten and the tires right themselves. 95,000 miles, no gas stablizer and no jacking....maybe I've been lucky for 18 years?
PS- a battery tender would be a good idea, seems all vettes slowly drain batteries while in hibernation, mine only takes about a month to drain one if not touched.
Old Sep 22, 2005 | 07:42 PM
aboatguy's Avatar
aboatguy
have a 4wd truck.
I have a 95 and to prepare for winter: I install my hardtop, check the coolant for antifreeze protection and make sure the rear defogger is working.
This was taken around April.
Old Sep 22, 2005 | 09:49 PM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
Here is my routine...in no particular order.....
1) Fill the tank with gas and add sta-bil
2) Change the oil
3) Wash and wax
4) Put the battery tender on to keep the battery fresh
5) Add some moisture buckets to aid in moisture prevention
6) Cover her up
7) Forget about her until spring!
-Rick
Old Sep 22, 2005 | 10:08 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I keep driving mine unless the snow is greater than a few inches.
Old Sep 22, 2005 | 11:01 PM
Speedvanish's Avatar
Speedvanish
I'm curious, why do you make sure the rear defogger is working?
Old Sep 22, 2005 | 11:13 PM
aboatguy's Avatar
aboatguy
So I don't have to scrape the window!!!
Old Sep 23, 2005 | 06:44 AM
Atok's Avatar
Atok
have a 4wd truck.
1. Fill the tank as full as you can and add Stabil. DO NOT store it with an empty tank. You could get condensation inside the tank. Run the engine a little after adding the Stabil to get it throughout the fuel system.
2. DO NOT put it on jack stands. The composite springs in our cars do not like to sag like that for very long. The composite springs are not like steel springs. All you should do it increase your tire pressure to the max (I use 45psi) and let it sit on it's wheels.
3. Change your oil. Do not leave old oil in the engine that long. The acids that build up in the oil can cause damage over time.
4. Check your antifreeze strength.
5. Get yourself a Battey Tender and leave it on your battery. I normally start mine once a month, but even doing that it doesn't keep the battery fully charged.
6. If you're worried about mice, place Bounce drier sheets around the engine bay, interior, and both tail pipes.
7. Clean it, wax it, cover it, and park it.
I live in North Eastern Canada, I'll be putting mine in hibernation in about a month and a half. 6 months off the road for me.
Old Sep 23, 2005 | 10:46 AM
aboatguy's Avatar
aboatguy
Old Sep 23, 2005 | 10:51 AM
MinnesotaWhite's Avatar
MinnesotaWhite
Ah hell...is it already time for these threads to be popping up??
Old Sep 23, 2005 | 01:13 PM
75 Red Vert's Avatar
75 Red Vert
Me too
Old Sep 23, 2005 | 05:21 PM
Hogan's Avatar
Hogan
From: First to Sign Grumpy's Hat Only 53 miles from Hell
St. Jude Donor '06-'09-'10-'11
2) Change the oil
3) Wash and wax
6) Cover her up
-Rick
Sounds about right!
If she is in a garage I ususally have her sitting on carpeting to keep moisture down. She might have to sit out this year under the car cover or maybe a temp garage if I can afford one.
Old Sep 23, 2005 | 07:42 PM
bdvdvh7's Avatar
bdvdvh7
Default oh nooooo
i was just thinking the same thing... the leaves are still on the trees!!!
Old Sep 23, 2005 | 11:07 PM
96KICKS's Avatar
96KICKS
CI 7-8 Veteran
Full tank of gas, no addditives whatsoever, clean car and cover it, hook up tender. Thats it. I usually go out and start it once a month, run the air and the heat, play a few tunes and wish it was spring!
To Winterizing my 95'
