I have recently noticed that if I am driving with my foot off the gas and turn on the A/C I can feel the car slow down. It really bumps it right when the A/C is turned on. It is most dramatic when I am going about 5 mph in 1st without my foot on the gas. The best way to describe it is just a bump. I can't tell if the car is noticeably slower with it on after the bump, but you can definately feel it right off for an instant. Do your cars do this as well?
Well gross engine output at idle is about 5 hp. The power required to turn the engine at idle in park or neutral is about 5 hp. The air conditioning compressor uses about 2 hp which is about 40% of the engine's idle output.
What does it feel like on the highway at about 65 mph and on flat smooth road? You may feel a very slight dip when the compressor cuts in. Does the compressor sound noisy when you have the hood up and watch it cycle? Does it cycle on/off very quickly?
I think I can feel it at around 45, but it is pretty insignificant. I haven't tried it at higher speeds. I like the cavalier comment, I bet that is a whole different story.
Yea, I don't think you have anything to worry about. Any compressor takes a significant amount of power when it first engages. You will notice it more at low speeds. If the compressor stalls you will DEFINITELY notice it at any speed.
How normal should it be!!!
when idling my 84 throws 13.9 amps yet when I engage the
AC it goes to 11.8 to 11.6,also while driving and appliying the
brakes and slowing down it feels like I'm dragging an anchor!!!
could it be that it needs a new compressor???
sorry if I highjacked this thread
Could be, and dont go cheap with a rebuilt one either, buy a new one if you can still get them.
"while driving and appliying the
brakes and slowing down it feels like I'm dragging an anchor!!!"
- it's supposed to do that.
No seriously, how can you tell a difference if the A/C is affecting power when on the brakes?
While cruising you should be able to feel it kick in and drain a little power, probably lose a little grunt unless you are WOT,
The RPMs shouldn't drop enough for voltage to drop, unless your A/C blower fan is draining it that much. A/C should kick on your other cooling fans also, which would cause a little drop too - more if you have some higher amp fans isntalled.
