Hood won't open
Old Sep 30, 2005 | 03:19 PM
Monkeynutz's Avatar
Monkeynutz
Default Hood won't open
My hood is stuck closed, the wires coming out of the underside of the dash are all mangled and loose and nothing I do seems to be working. I just want to be able to open the hood to change the oil. Any idea how to do this?
Old Sep 30, 2005 | 04:46 PM
Edison Trent's Avatar
Edison Trent
Cruise-In VII Veteran
St. Jude Donor '06-'07
This happened to me once. Try gripping the cable sleave with a pair of vise-grips and pulling the actual cable with a pair of pliers. The other option is a special tool that you can slid under the hood next to the A pillar and the door on the driver's side... hope this helps.
Old Sep 30, 2005 | 05:05 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Also, you can remove the front tires, and splash guard, then get long screwdriver and move the lock, requires 2 persons if you get to this.
There are also threads with links to how to make the emerg hood release tool.
You might want to add this if you get the hood open, just in case .
Old Sep 30, 2005 | 06:25 PM
Slipjoint's Avatar
Slipjoint
there is a picture of a hood release tool & how to use it on my wegpage - bottom album - t
http://www.picturetrail.com/tomhudson
there is a latch on each side you must trip - take your time - if you have any questions let me know off line
Old Oct 1, 2005 | 05:33 PM
Monkeynutz's Avatar
Monkeynutz
How do I purchase the tool?
Old Oct 1, 2005 | 05:43 PM
Slipjoint's Avatar
Slipjoint
if you don't want to make one for a couple of bucks - i think mid america sells them - 20 bucks plus S&H
Old Oct 1, 2005 | 07:37 PM
jabez's Avatar
jabez
Push down on both sides of your hood to make sure its aligned. Then pull hood release again. Sometimes its just frozen stuck or just mis-aligned.
Old Oct 1, 2005 | 07:45 PM
85C4fanatic's Avatar
85C4fanatic
Did this happen after you were driving your car? I had a problem with opening the hood when the car was hot for awhile. I readjusted the cables and added some grease to the catches and havent had the problem since. I have also heard of have you and a helper like described before have someone push down on the hood and the other pull the cables. Good luck I knwothe feeling
Old Oct 2, 2005 | 10:08 PM
shotchkiss's Avatar
shotchkiss
Here's the instructions on how to make the tool.
http://www.corvetteactioncenter.com/...n.php?qstId=87
To Hood won't open
By Michael S. Palmer | 2026-06-03 09:39:05
