imron
Old Oct 3, 2005 | 07:35 PM
rightofway's Avatar
rightofway
Default imron
anybody paint their vette with dupont imron paint or what paint did you use
Old Oct 3, 2005 | 07:53 PM
bogus's Avatar
bogus
if I am not mistaken, that paint went off the market when the EPA limited VOC's.
Old Oct 3, 2005 | 08:09 PM
aboatguy's Avatar
aboatguy
I think that there are new low VOC IMRON paints in production. I hope that it is as good as the old.
Mike
Old Oct 3, 2005 | 09:20 PM
cavu's Avatar
cavu
Imron was and stll is very good paint. However, there are much better paints on the market now. What you want is a very good base coat clear coat paint. I recommend Dupont Croma Base with the High Solids clear. This is the best paint I have ever used. The High Solids clear is very glossy and the paint looks wet even years down the road.
Old Oct 3, 2005 | 09:23 PM
Brian9's Avatar
Brian9
My 68 convertible had Imron paint on it and i loved it... not sure of the availability now though....
Old Oct 3, 2005 | 10:21 PM
okies93's Avatar
okies93
St. Jude Donor 06
dupont has always been a fav. i have recently been using limco 1-2-3, simple product to use and works great on tractors that i restore. i would use dupont if it was easy to get. small town has limited access to stuff
Old Oct 3, 2005 | 11:48 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Hey, Cav, how about a little primer on the newest paints, what they are, how they're made, etc.?
Old Oct 4, 2005 | 10:18 AM
redwing76's Avatar
redwing76
I sprayed Imron for 10 years on Peterbilts average paint job was 5-6 gallons. It hard to use in a cold climate (Portland Ore.)
Its really hard to blend with and its highly toxic. A nieghbor sprayed his 911 with Imron and his wife found him the garage out cold.
5 days in a comma the docs said theres no antidote for polyisocianates.
You iether pull out of it or you die. Theres well documented cases of death and near death by non-pros using Imron. Not only that but theres also serious central nervous system damage with use of Imron or any modern paints. Leave the painting to the pros.
It startches easly and spot repair is not recomended by Du Pont.
Avoid Imron.
I use Centari or Chroma Color. If at all possible use a single stage.
To imron
