Lights
Old Oct 3, 2005 | 08:33 PM
JD JOHNSON's Avatar
JD JOHNSON
Default Lights
No backup lights fellows.....It's on the same fuse as the Shift from 1st to 4th....Fuse is a 15 amp seems to be ok...Any ideas... thanks
Old Oct 3, 2005 | 08:47 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Check the switch on the bottom of the shifter.
Old Oct 3, 2005 | 08:51 PM
JD JOHNSON's Avatar
JD JOHNSON
Thanks 65Z01 .....I'LL CHECK IT OUT NOW.....
Old Oct 4, 2005 | 11:00 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Well??
Larry
code5coupe
Old Oct 4, 2005 | 12:02 PM
corvette1989bham's Avatar
corvette1989bham
I hate it when people ask for help and dont post what year,style car they have. DEPENDING on that, the right rear interior compartment, pull the carpet back and find the body wiring harness connector, most likely it is corroded bright green and even some of the wires may have melted, if so, by pass the harness with a roll/crimp connector or buy you a new correct connector from a salvage yard and toss the old body connector away. But of course, do this after you check the back up light socket with a test light.
To Lights
