Rubber coating on interior panels
Old Oct 6, 2005 | 01:30 PM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
Default Rubber coating on interior panels
Has anyone found a good substitute for the rubber coating used on the interior plastic panels? I believe GM called this 'DULSO' but I cannot find this. I was looking to touch up a few small areas where some of this has worn off over the years. Is there any kind of rubber or vinyl paint (black) that could be used for such a repair? thanks.
Old Oct 6, 2005 | 03:46 PM
yellowlust's Avatar
yellowlust
While there are a couple people who have tried to refinish the plastic, new repro parts are available for ~$120 or less if you are talking about the console (high wear part).
The bezel around the radio is something like $30 from GM...
I've got a broken cup holder door so repro it is...
Old Oct 6, 2005 | 04:08 PM
IrishJoker's Avatar
IrishJoker
Yep, just purchased the new console from Corvette America - they also sell the vinyl spray - don't know how good it works but I am going to experiment on my old console when I replace it and if it works, well I got a spare! I am such a pack rat
Old Oct 6, 2005 | 04:33 PM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
Let me know how the vinyl spray works. What PN is this from CA?
Old Oct 6, 2005 | 06:34 PM
bdvdvh7's Avatar
bdvdvh7
another brilliant general motors design... many have tried to refinish to some success. better to by a replacement.
Old Oct 6, 2005 | 08:47 PM
mfi's Avatar
mfi
Old Oct 6, 2005 | 09:22 PM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
BTW, the GM producted used for this is by a company called DUSLO (not DULSO). I am going to try the following to see how it works for a small area repair and then for a full panel on a spare unit I have.
http://www.eastwoodco.com/shopping/p...=PLASTIC%2CDIP
Old Oct 6, 2005 | 09:57 PM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
Someone on here had a cool carbon fiber kit. Where can you get the oem repro?
Old Oct 6, 2005 | 10:47 PM
USAFPILOT's Avatar
USAFPILOT
Has anyone ever just covered the plastic parts with leather to match?
Old Oct 7, 2005 | 10:32 AM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
The OEM repro can be obtained from Ecklers, MID AMERICA, any # of online vette parts/accessory distributors. But they cost over $100. I just bought a used one from a forum member that had just a little wear on it so I am looking to repair that small area. (Used one cost me $45).
Old Oct 7, 2005 | 03:20 PM
IrishJoker's Avatar
IrishJoker
Will do!
Old Oct 7, 2005 | 03:31 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Here's a vinyl & dash repair kit for rather low cost from Eastwoon:
http://www.eastwoodco.com/shopping/p...ProductID=2016
They have another kit for $10 more containing a foam spray for large cracks.
I've not used it but looks like you could "texture" the new surface to closely match the original.
I've used JB Weld & vinyl paints to repair plastic parts but the two problems I've encountered are getting sufficient strength to avoid future cracks and getting the repaired surface texture to match the original.
I've recently had success with repairing my door panels by using thin Al sheet with some JB Quidk Set under and over the Al. This is a "hidden" repair so surface texture isn't an issue but at the repair has proven to be strong enough to stand some flexing over a period of a few months.
Old Oct 7, 2005 | 05:05 PM
capkarl's Avatar
capkarl
St. Jude Donor '09,'10,'11,'12,'13,'14-'15-'16-'17-'18-'19-'20-'21
Is this the same stuff that is used on the inside door grips? My drivers side show wear.
Old Oct 7, 2005 | 06:03 PM
cavu's Avatar
cavu
Why not just wet sand the parts and refinish them with a good satin black paint? It would last longer, and it would be very hard to tell the diference visually.
Old Oct 7, 2005 | 06:15 PM
mfi's Avatar
mfi
SEM makes a product called problem plastic repair, 3M also make an adhesive for plastic. You have to roughen up the surfaces or it won't stick. I was told to only use adhesives made for plastic, epoxy won't work. I've been trying to get my passenger door panel back in shape so it will stay on the top, not much luck but it holds a little better. Auto body supply shops are the only place I go for this stuff.
Old Oct 8, 2005 | 10:50 AM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
NOt sure. But if it is the rubber coating , then it is probably all the same stuff (originally the DUSLO). I will post how the eastwood plastic dip works once I get it.
Old Oct 8, 2005 | 10:52 AM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
Yes this is a good alternative, however I am not looking to strip the entire assembly just to repair a small area where there is some wear. So I am looking for something that will do the rubber coating spot repair. I am going to try the Eastwood Plastic Dip (in black) and see how this works out for small area repairs. I can practice on a spare shift panel I have.
Thanks.
Old Oct 8, 2005 | 11:31 AM
yellowlust's Avatar
yellowlust
Thanks.
Spot repairing the rubber coating does not sound like a feasible solution, it will never match.
To Rubber coating on interior panels
