need help with headlight
Old Oct 7, 2005 | 11:27 AM
95polo's Avatar
95polo
Default need help with headlight
I am trying to change the bushings in my headlight motor. I can't get the roll pin out of the shaft, it is seized. After trying to hammer it out with a punch I tried drilling it. Do I need some kind of special drill bit. The metal the pin is made out of seems very hard and my bit won't cut into it. Now where I have hammered on it and drilled on it the pin is belled at both ends. Tech tools said the pin should come out easy. I am afraid to hammer on it anymore I don't want to bend the shaft, I probably have already bent it. How do I get this thing out?
Old Oct 7, 2005 | 12:33 PM
95polo's Avatar
95polo
Got it taken care of. Soaked it with WD-40, took a break, then beat the hell out of it. I'll find out later if I tore anything up.
Old Oct 7, 2005 | 03:37 PM
95polo's Avatar
95polo
Just finished up everything is working fine!!!!
Old Oct 7, 2005 | 03:50 PM
JLB05's Avatar
JLB05
Glad to see you got it worked out. I have a '94 (polo green also) and I'm getting a klunk klunk klunk noise whenever I turn on/off the headlights. Is this what you were experiencing?
Old Oct 7, 2005 | 03:54 PM
95polo's Avatar
95polo
yes
Old Oct 7, 2005 | 05:02 PM
capkarl's Avatar
capkarl
St. Jude Donor '09,'10,'11,'12,'13,'14-'15-'16-'17-'18-'19-'20-'21
You need to change the bushings.
To need help with headlight
