How difficult is it to replace shocks? I have never done this myself on any car. Is it low risk?
Low risk....hmmm don't know about that.
Fronts and rears are fairly easy. (Torque wrench is needed)
If you have two floor jacks it makes it easier. One for the car and one to hold up on the front suspenion knuckle. Otherwise when you remove the bolts the whole assembly drops to the floor. Basically the fronts you have a top nut and two on the bottom.
The rear are held to the bottom by one large bolt, and the top you remove the whole plate I think it is two bolts and then remove the top of the shock from the plate away from the vehicle. Assembly is the reverse. I don't have the torque values off hand but can get them if needed.
My '88 Shop Manual is a bit sketchy on servicing the shocks.
For the fronts in only says to remove the service plate on the inner wheel well over the shock nut if difficulty in removing that nut.
For the rears it says only to jack the vehicle, remove the lower mounting bolt, remove the upper bracket and then the shock from the bracket. Then reverse the sequence for installation.
This is pretty much it for changing shocks. The fronts can be probably be changed without removing the tires, but I don't recommend it as it would be a pita to work around the tire.
Spray the bolts liberally with some liquid wrench before trying to crack them loose or you could end up rounding off a bolt head or breaking the bolt.
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Did our FX3 shocks last year, had a lift and used a jack stand per the manual, but was pretty easy.
However, if you have the FX3 (Selective Ride) shocks, you must take care when doing the rears as the actuator (motor) wire isn't that long and is up in the frame. Also, whereas you can buy new FX3 shocks from Ecklers for around $180/per shock, new rubber bushings were hard to find for us, and were needed.
We love the ride in the Vette now with the new Bilstein FX3 shocks from Ecklers.
Stay away from Monroes -- put them on our 2000 Pontiac Trans Am rear (thinking they were a good replacment to OEM), and they make the rear ride very harsh and hard over bumps versus OEM's (which were a Bilstein mono-shock or equivalent from AC Delco).
