Locking Lug Nuts
Old Oct 9, 2005 | 09:49 AM
ZAWA's Avatar
ZAWA
Default Locking Lug Nuts
Lost the removel tool, how far up the creek am I? They are on a 85.
Old Oct 9, 2005 | 10:12 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Not very far; nearly any good tire place will have a socket that they will drive over them and remove em. Just have another set w/ key ready to go on.
Old Oct 9, 2005 | 01:53 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If mine happened to match yours I'd let you borrow it. You'd have to post a nice closeup pic of your locking nut though.
Old Oct 9, 2005 | 02:55 PM
Impala Balko's Avatar
Impala Balko
I had the same prob when i bought my car. I bought a slightly oversized 12pt deep socket at Sears I believe mine was a 20mm or a 21mm. Bang the socket on over the lock nut with a BFH (Big F&*kin Hammer). and use a breaker bar to loosen them up. I heated mine up real nice prior to doing all this with a couple of 100-0mph stops. They came off like buttahz. By the way no tire place is going to touch your locknuts because they dont want to scratch your rim and have to replace them that is the problem i had. so that is why i used the method i just told you about.
Old Oct 10, 2005 | 06:45 PM
ZAWA's Avatar
ZAWA
1'' 12 pt, socket and a big and I do mean big hammer did the job. Thanks for the help, lug nuts can still be used if I find the key.
Old Oct 10, 2005 | 06:59 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Default Tire Center
Go to any tire center. Somehow they manage to balance and rotate my tires without even ask for it. They may do it for free
To Locking Lug Nuts
