headlight upgrade?
Old Oct 9, 2005 | 09:10 PM
WAYWRONG's Avatar
WAYWRONG
Default headlight upgrade?
My 95 has the plastic headlights i would like to go to a brighter light these seem like candles .will the glass lights be too heavy for the motors?
Old Oct 9, 2005 | 09:50 PM
corvette1989bham's Avatar
corvette1989bham
yes they can handle it, may wear out a little quicker but they are going to wear out anyway, I use the Silverstars in mine.
Old Oct 9, 2005 | 10:02 PM
zoro's Avatar
zoro
Has anyone swapped in Hella or Bosch headlights with replaceable halogen bulbs? Would the standard plugs work with these?
Old Oct 9, 2005 | 11:34 PM
mdell2's Avatar
mdell2
Silverstars are the way to go. Huge improvement for $40.00
Old Oct 10, 2005 | 07:51 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
i will have some Hid projection units ready in the next few weeks
Old Oct 10, 2005 | 10:02 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I have the Hella's with H4's. Plug and play....
Larry
code5coupe
Old Oct 10, 2005 | 01:21 PM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
You gotta let us know how those turn out. Where did you pic those up?
I seen similar ones on e-bay
Old Oct 10, 2005 | 02:41 PM
ElisTwoCents's Avatar
ElisTwoCents
St. Jude Donor '05 thru '24
How labor intensive/install will this kit be. Looks be be pretty straight forward. Let us know how that works out and Im sure you'll see plenty of sales if the price is right
Old Oct 10, 2005 | 02:46 PM
zoro's Avatar
zoro
Larry
code5coupe
great news
thanks very much
what wattage bulbs did you use?
Old Oct 10, 2005 | 05:49 PM
GS057's Avatar
GS057
2018 C6 of Year Finalist
Old Oct 11, 2005 | 02:12 AM
red-roadster's Avatar
red-roadster
Default headlite upgrades
bosch lenses with piaa 135/90 bulbs - awesome
Old Oct 11, 2005 | 06:59 AM
USAFPILOT's Avatar
USAFPILOT
There is now way I'll spend over a grand on headlights. It must be some kind of fashion statement.
Old Oct 11, 2005 | 09:49 AM
MYCoupe's Avatar
MYCoupe
Larry
code5coupe
This is the same setup I have and I'm using stock wattage H4 bulbs. What a difference the first time I used them at night! I could finally see again. Highly recommend this mod.
Old Oct 11, 2005 | 10:04 AM
Strick's Avatar
Strick
I tried the H4 bulb set ups and was disappointed. AutoZone let me try them out and gave me a refund. So far the SilverStars are the best, but still not bright enough for me. So I drive a little slower at night on dark roads, don't want to hit a deer or anything.
edit: Anybody notice how bright those Ford F-150s are? They are bright, especially when they are behind you. Now if we could just figure out how to put those lights in our C-4s.
Old Oct 11, 2005 | 07:46 PM
C5Jimmy's Avatar
C5Jimmy
Saw a member a couple of months back post about HID lighting he put in his Grand Sport. Nice!!
Old Oct 11, 2005 | 11:11 PM
Hotred94's Avatar
Hotred94
Autopal European conversion with 90/100 H4 bulbs--plug and play.
Old Oct 11, 2005 | 11:37 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
If you look at my website the C4 kit has the same output as the c5 kit but the c4 is hi and low HID
This is not a inexpensive solution.
But they are bright you will never complian about headlights being too dim.
Old Oct 12, 2005 | 07:05 PM
red-y's Avatar
red-y
Old Oct 12, 2005 | 08:40 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
I mounted the good Hellas with the 55-65 bulbs. Lots of light!! And if you set them a tad high you can be just as irritating to the other drivers as do the ricers with thier bazillion candle power retna burners.
To headlight upgrade?
