Weak acceleration
Old Oct 16, 2005 | 09:31 PM
PsychoNumber1's Avatar
PsychoNumber1
From: Behind The Redwood Curtain, The State of Jefferson
Default Weak acceleration
any reason, after sitting for a few days in the rain, to cause the acceleration to suck so hard? I had it floored after I got on the highway and strightened out, 20-60 took about twice as long as ever.
if not, any other ideas?
Old Oct 16, 2005 | 09:39 PM
Biff Buyer's Avatar
Biff Buyer
check your little drain plug where your gas cap is. That drain hole can get clogged and cause that compartment to fill with water. Rain will then seep into your gas tank. Happend to me, i took a garded hose and flushed her out. Also, your ignition could be screwed and getting water in it. More than likely under your Distributer cap or somthing.
Old Oct 17, 2005 | 01:08 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Those pre cats can fall apart at anytime and clog the main cat.
Might want to bang on your exhaust ayatem and listen for any rattles.
Old Oct 17, 2005 | 01:30 AM
PsychoNumber1
the whole thing rattles
I think the tranny shoppe didn't get them back on right since they're rusted out.
To Weak acceleration
