I just installed a new master cylinder which I bench bled before installing. I know that I have to bleed the entire brake system at this point. The question I have is should the brake pedal be somewhat firm before bleeding the system? Right now the pedal goes down to the floor and does not build up resistance as I pump the pedal with the engine off. Did I not bench bleed the cylinder properly or will the pedal come up when I bleed the system. I would hate to bleed the system only to have to do it all over again if the cylinder has to come off. Thanks for any help.
If you bleed the system the master cylinder will fill. Start with the RR thel LR then RF and LF last. Don't know what type of bleeder you have but a clean mayo jar works very well. Run a piece of tubing from the bleeder valve to the bottom of the jar with enough fluid in the jar to cover the end of the tubing. Open the bleeder valve and have someone pump until you get clean fluid with no bubbles. Close the bleeder valve and goto the next wheel. Make sure you don't let the master cylinder get too low. This is a neat and clean method that insures both a flushed system as well as one free of air.
Start the engine and begin to bleed the system, beginning with the farthest point.
I cracked open the bleeder, installed a length of hose over the end and imersed the other end into a can of brake fluid. This assured that as I pumped the brake air would not be sucked back into the system and it's easy to keep an eye on the fluid level in the MC.
Thanks for the quick response Do I bleed with the engine running or off?
Thanks for the response, you just answered my next question regarding the engine on or off
I don't think it makes a lot of difference if the engine is running or not. I do mine with it off.
vinnies87, I was taught to start with the caliper the fartherest away from the master cylinder and work toward it. That is RR,LR then RF and LF last. Haynes says RR,LR,LF then RF. I wonder if it really makes a lot of difference.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You want it extended out to the point where it comes close to the piston without touching it. You can tell by slipping the m/c on there when the pushrod is too long.
My question is whether or not running the engine causes that pushrod to move. Until I check that, I'm not 100% sure that tip on adjusting it is correct.
Get a MityVac off ebay did mine in about an hour.The MityVac was ~$30 with all the fittings for the brake bleed as well as vacuum testing.Just fill the MC up and bleed till clear.Boy it was nasty too now I can see the bottom of the MC.I used Prestone Dot3 synthetic and the brakes work much better.This is one tool I will use again much easier than manually pumping the brake.Some guys use speed bleeders they replace the fitting you have on the calipers.Use some PB Blaster on the fittings the day before you do it and just before you do it hit them again with it.They all loosened with no trouble.You do not start the engine to do it this way and it makes it tuff to get air in the system this way.
It doesnt matter if you have a double reservoir master because if you do the front and rear are independent of each other. Just start on the right on both front and rear, which is the furthest from the master for either. It really doesn't matter if you do the front or rear first. Other than being both controlled by the brake pedal and booster they are seperate. You can have dirty fluid in one and clean in the other.
Are you referring to the rod that sticks out of the booster? If so, what did you have to do to adjust it?
You have to use a pair of vice grips to hold the cylinder the bolt screws into. It was impossible to do it by feel for me as far as having it just miss the master cylinder. What happened would be that after I turned the bolt, then put the MC back on.. the wheels would spin freely (had front tire off ground for testing) Then I'd start car and apply the brakes... the brakes would then remain in contact w/ the rotor after released. so, by trial and error, I would remove the MC, turn the bolt a little bit, put MC on, test, rinse and repeat. Important note... you should turn the bolt as little as a quarter turn each time.
Disclaimer: There may be a better way to do this...... I am unaware of it.
