Ok, time to put her away for the year up here in Michigan. I typically fill the car up and add stablizer to the fuel. I had a getlemen tell me he stores his empty for fear the fuel will gum up over the winter.
If it matters, mine is stored in an unheated garage and I typically start it from time to time and let it run for 10 to 20 minutes.
Which way is correct, full or (nearly) empty?
Thanks for the input.
Reason: spelling error
Full, and add stabil. Don't run the car during the winter months unless you are going to bring everything up to full operating temps. I never run mine during the winter . Just let it sleep. I read that if you keep starting it without getting it good and hot you won't burn the contaminants out of the oil. Just something I read quoting a GM engineer.
But I top off my gas tank with Shell V Power. No stabil. I figure that modern gasolines have enough additives and cleaning agents in them taht four or five months of storage isn't going to mean much. I mean, they store gasoline for a better part of a year in bulk storage facilities.. and then you put it in your gas tank! As long as I you use a good, premium fuel, I think that Stabil in unneccesary. I do, however, use stabil in my small engines, but mostly because I use a lower grade of gas with less additive in them...
I also run my car once a month, at idle, for about 30-40 min to get everything up to temp during the winter. I just feel better knowing that things circulate at least once a month...
Not to mention that if you fire it w/out driving at idle only, chances are that condesation will sit in the exhaust/mufflers regardless of full operating temp. JMO
