Interior paint/dye
Old Oct 24, 2005 | 01:56 PM
zoro's Avatar
zoro
Default Interior paint/dye
I need to paint the plastic sill plates on my '85 and wondered what was the best product. SEM paint or something else?
Old Oct 24, 2005 | 02:41 PM
Bluevette85's Avatar
Bluevette85
I did this on my 85. I used dye from Corvette America. Get it direct from them because they supply it to the other catalogs. It's important to prep the plastic and I went to an auto paint supply shop and bought SEM plastic cleaner and SEM plastic prep(I can get you the exact name later tonight).
Old Oct 24, 2005 | 03:12 PM
zoro's Avatar
zoro
yes, that would be appreciated--imagine it is something so the new paint will adhere better?
Old Oct 24, 2005 | 05:27 PM
mikey whipreck's Avatar
mikey whipreck
I bought matching paint from ecklers (or was it midamerica)...
Anyway - it worked really well. You can check my website for before/after pics.
Just take your time with the prep work.
You can use soap and water, for the same effect as the more expensive plastic and vinyl prep products. The basic Idea is to remove any silicon or dirt that are on the pieces...
Old Oct 24, 2005 | 06:54 PM
zoro's Avatar
zoro
thanks for the link Mikey
nice seeing a project like that come out so nice
how did you do your wheels?
Old Oct 24, 2005 | 07:40 PM
Bluevette85
SEM Vinyl Prep #38343
SEM Plastic Prep #38353
SEM Sand Free #38363
Old Oct 24, 2005 | 07:46 PM
zoro's Avatar
zoro
thanks BV!
Old Oct 24, 2005 | 11:37 PM
CG77VETTE's Avatar
CG77VETTE
I'm not sure what color you need, but I had a hard time matching my '86 Medium Grey leather interior. The medium grey I purchased from one of the catalouge companies wasn't even close. I had my interior paint custom blended using the GM paint code to match exactly. If you have medium grey and need the paint code, let me know.
Old Oct 25, 2005 | 02:38 AM
zoro's Avatar
zoro
thanks CG
mine is blue--I think I will see if someone can match what I've got and mix up the paint
Old Oct 25, 2005 | 09:18 AM
mikenfl's Avatar
mikenfl
Actually, the prep products are adhesion promoters. There's a different one for vinyl and hard plastic. The one for vinyl will soften the surface when it's sprayed on. I did a color change on mine this summer. I washed every piece with soap and water first, scrubbing with a stiff bristled brush. Then cleaned with Ditzler DX 330 wax/grease/silicon remover, and then the prep spray. I used SEM prep and paint (it's not really dye) products. You might get good results with just a good washing, like the above post suggests, but this worked good for me.
Old Oct 25, 2005 | 11:15 AM
zoro's Avatar
zoro
thanks Mikey
looks like we've got the same car
To Interior paint/dye
