Help!!!
Old Oct 24, 2005 | 07:51 PM
Buttz's Avatar
Buttz
Default Help!!!
Every time I shift form park to any gear I get a loud klunk from what sounds like the rear end. I had a mechanic look at it and its not the u-joints. any ideas? Its a 87 auto
Old Oct 24, 2005 | 08:44 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
This same question was asked at Chris Petris' C4 Bloomington Gold class this summer. I am not home to look at my notes but I think he said it had something to do with the transmission but not to worry about it as a mild thunk is normal. If it is REALLY bad then I would advise that you have the tranny checked.
Old Oct 24, 2005 | 08:46 PM
badseed1's Avatar
badseed1
check and see if the trans mount is good
Old Oct 24, 2005 | 09:33 PM
Buttz's Avatar
Buttz
ow ya its not mild at all it sounds like you smacking a hammer on the rear diff. also it only happens once the car is driven and warmed up.
Old Oct 24, 2005 | 11:05 PM
Pete K's Avatar
Pete K
If it is not the u joints, check for excessive backlash in the trans and rear. The aux valve body transmissions (early87 and on) had a valve to help cushion that hard apply.
To Help!!!
