new headlight problem?
Old Oct 24, 2005 | 09:00 PM
viau86's Avatar
viau86
4th Gear
Default new headlight problem?
i have looked at all the forums to see if anybody has jad this problem and did not see it ,so bear with me ,,new to the site, my left headlight opens fine but does not close ,so if i turn the **** under the motor it will close but when you get it all the way closed it falls back open about an inch and when you turn the **** you can see a crack and it moves when you turn ****,, crack in the housing opens and light falls back open about an inch ? my ? is do i need a motor or just a housing or is there a way to fix the housing?
Old Oct 25, 2005 | 11:49 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
You have an 86 right? Those models don't have bushings so you can rule that out. Sounds like it might be your motor gears. You can upgrade the OEM plastic gears to sturdier bronze ones from the speciality catalogs like MAM, Eckler's and Corvette Central.
Old Oct 25, 2005 | 01:04 PM
RWDsmoke's Avatar
RWDsmoke
Can you hear the motor running? When my plastic gears stripped the headlight would try to close but the motor would keep running. My right headlight would close but not open and I found a blown fusible link. And someone had assembled the motor incorrectly which also left a lot of play in the motor. (The rubber pads were missing out of the gear.) The things you find when you buy a car that someone else tried to fix and gave up on.... The factory service manual has a very good troubleshooting section for the electrical part.
Old Oct 25, 2005 | 07:46 PM
viau86's Avatar
viau86
4th Gear
thanks for the info guys did not know 86 did not have bushings,,,motor runs to open it ,but only closes it about half way and like i said when you turn the **** on bottom of motor to close it the rest of the way,, just about when you get it closed it falls back open about one half inch and as you turn the **** on the bottom of motor you can see a small crack open on the plastic housing and it falls back open ..think ill pull it off this weekend and put car in its winter storage ,god i hate that thought,just got it in late july it,s a 86 pace car convt with 4 speed stick its a great driving car and has only 69000 on it red metalic tan top and tan guts plan on doing a few mods in spring ,did flowmasters already sounds great my first convt since my 66 i love it,, cant wait for spring already,,
Old Oct 26, 2005 | 10:47 AM
onedef92's Avatar
onedef92
You'll probably end up buying a used headlight motor from a Corvette salvage yard. Might be a good idea to get two so you can scavenge parts from it.
To new headlight problem?
