rear end
Old Oct 28, 2005 | 07:50 AM
sonomacrew01's Avatar
sonomacrew01
Default rear end
no, not on a hot woman but 2 questions...
1) how do i know what gear ratio I have...RPO code list?
2) I have the driveshaft off and as I rotate the spline into the rear housing, there is a little bit of play before I see tires moving. Is this normal? If not, what is this an indication of?
ps, I'm going to replace ALL U-joints nontheless.
Old Oct 28, 2005 | 07:56 AM
92ZR1WANNABE's Avatar
92ZR1WANNABE
1. Either A RPO list (which i don't have in front of me) Or simple rotate the input yoke 1 full turn and count how many times the output rotates.
2. A little is normal, its called backlash, Nothing to worry about unless its really excessive.
Old Oct 28, 2005 | 11:24 AM
sonomacrew01
GM3....looks like a 3.45. Good for acceleration but not for top end...
Old Oct 29, 2005 | 12:06 AM
Ericsvette's Avatar
Ericsvette
If your RPO list says GM3 than you have 3.45's. That's what I have in mine. The RPO codes 1993 are as follows:
GM1 - 2.59
GM3 - 3.45
GU2 - 2.73
G44 - 3.07
3.07's would probably be the best for off the line acceleration and top end.
To rear end
