Hatch Release??
Old Oct 29, 2005 | 08:14 PM
Donne Trav's Avatar
Donne Trav
Default Hatch Release??
Suddenly my "rear hatch release" slide button located inside the edge of
drivers side door doesn't activate/open the rear hatch on my '94.
Could this be a "fuse" problem? Is anyone familiar with this occurrence?
Old Oct 29, 2005 | 09:10 PM
shacky's Avatar
shacky
From the service manual:
Old Oct 29, 2005 | 09:34 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Does the release in the glove box or the right hand door work?
If so, I'll take a wild guess and say the switch is bad or has become disconnected behind the door panel.
Old Oct 30, 2005 | 03:07 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
I'm having a similar problem with my 93: the switch on the door won't open the hatch but the on in the center console will. Also, the interior lights don't go on when I open the driver side door and the PKE won't lock the doors unless I open then close the passenger door.
To Hatch Release??
