Fuel Filter
Old Nov 7, 2005 | 09:33 PM
jlsru's Avatar
jlsru
Cruise-In V Veteran
Default Fuel Filter
I think I need to replace the fuel filter on my 86.Can anyone tell me where it is located and how difficult it is to replace?Thanks
Old Nov 7, 2005 | 09:41 PM
Monkeynutz's Avatar
Monkeynutz
You should replace it every once in a while it can make a good bit of difference. You can get them for like $10-20.
It's a small rounded rectangular box but I think it's slightly different than my 84's fuel filter.
Old Nov 7, 2005 | 09:48 PM
INTIMIDATOR ZO6's Avatar
INTIMIDATOR ZO6
Try looking for it on the frame rail passenger side across from the engine's starter. Thats where it's at on my 90 & 93 Vettes.
Old Nov 7, 2005 | 10:47 PM
John A. Marker's Avatar
John A. Marker
Default Not too bad.
Look on pass. side across from starter on frame rail (like indicated above), it should be round canister about 2-1/2" in diameter and about 3-1/2" long. I park my vet on a upward slope, block rear wheels and then jack up front end. This puts the filter at the same lever or higher than the tank. Next start the car and pull the fuel pump fuse from the fuse block and let the car run out of gas and die. There should be no or very little pressure in the line at this point. (Turn off the key now). Note that there should be a clamp that holds the filter to the frame rail. Remove the clamp. (PITA) Next, use two wrenches to remove the filter, one to hold the filter and the other to turn the nut on the line. Remove the old filter and install the new one. Be sure to note the flow direction as noted on the filter. I use the Fram G3727 on my 85. Tighten up the fittings, replace the fuel pump fuse and start the car. Check for leaks. You should be good.
You might loose some fuel when changing the filter, so use rags or a pan to catch the excess.
Many only change their filter once per year (based on how often they run their cars). I usually change mine between 10,000 and 15,000. I write the Odometer reading on the filter when I change to a new one as a reminder.
Good luck, should be about 1/2 - 3/4 hour job based on experience.
Old Nov 7, 2005 | 10:58 PM
dock351's Avatar
dock351
St. Jude Donor '06
but I would add that on my 90 the filter was hidden behind a heat shield.
Old Nov 7, 2005 | 11:50 PM
Jet-Jock's Avatar
Jet-Jock
I found that picking up the little plastic tool to release the fuel lines at their quick connect points which made the job much easier. I released the lines after all the above was done, then pulled the whole thing down and out. Removed the filter from the lines and installed the new one then fed the whole assembly back up in there.
Tip, release the bracket first before you release any of the fuel lines. Keeps you from getting drenched in fuel while trying to get that bolt off.
Also manual suggested releasing the fasteners to the fuel lines along the rail back to the front of the rear wheel well. Makes it much easier to manipulate the assembly.
Old Nov 8, 2005 | 05:41 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
open the filler cap and release the pressure on the system before you remove the filter or you will loose a lot of fuel.
Old Nov 8, 2005 | 01:01 PM
Saisling's Avatar
Saisling
St. Jude Donor '05
What everyone else said, and this is what it looks like if you want a better idea... Put your head under the car behind the passenger side wheel and slide under (if you can wothout lifting it) far enough to look at the engine side of teh frame rail... it's right there.
Old Nov 9, 2005 | 02:18 PM
jlsru's Avatar
jlsru
Cruise-In V Veteran
Thanks everyone for the help.I plan on ghanging the filter this weekend.
Old Nov 9, 2005 | 04:28 PM
85 500 horse's Avatar
85 500 horse
On my 85, it is located in the same place as others have described; Passenger side under the frame rail. Before I changed mine, I didn't remove any fuses or the gas cap. If I had known, I probably would have, because A LOT of fuel ran down my arms during the swap. Man did that burn. It's really not difficult to change. My car was on a lift which made it much easier, but it can be done on jacks.
Old Nov 9, 2005 | 06:18 PM
DarkBlue88's Avatar
DarkBlue88
From: Charlotte NC, behind someone going 10 under the speed limit
The best way I found was to jam a 5/8 line wrench up on the top fitting against the frame or exhaust and turn the whole fuel filter with the lower end of the filter's wrench flats, 13/16 i think. He didn't say coupe or vert, vertibles are much harder.
Old Nov 10, 2005 | 12:42 AM
Zix's Avatar
Zix
Originally Posted by joshwilson3
What brand fuel filter you guys recommend?
I use the NAPA Gold filters and have had very good luck with them
Old Nov 10, 2005 | 09:14 AM
Dynabob's Avatar
Dynabob
From: What do I know anyway? I'm just a 50 year old No0b
Put the Purolator in my '89. It was under $6.50 at Advance Auto
Old Nov 10, 2005 | 09:33 AM
CoffeeDrip's Avatar
CoffeeDrip
Like they all said. It is across from the starter. You will need a 21mm & a 16mm wrench( prefer to use LINE wrenches , but regular open end should work). Also a 10mm socket, small extension, & rachet. The 10mm is for the bolt that holds the strap in place( which holds the filter in place). The bolt is above the filter.
I didn't even have to jack up the car to do this. There is no shroud to take off.
Just stick the 21mm on the filter & use the 16mm to break the line loose from the filter. After both sides are broke loose. Remove the 10mm bolt securing the filter. Pull the filter down & then pull the lines out of it. Replace is just the opposite.
JUST remember. Attach the fuel lines to the new filter(attach but do not tighten all the way) BEFORE you secure the filter to the car. It is a PITA to try & get the lines lined up & tightened properly if the filter is already tightened down & you can not move it.
I use an ACDelco filter(or NAPA gold)
To Fuel Filter
