Gas mileaged increased
Old Nov 8, 2005 | 03:07 PM
LT1Vetteguy78's Avatar
LT1Vetteguy78
Default Gas mileaged increased
Welp,
about 99% of the time i use Mobil/Exxon gas 93oct....i was getting between 18.5 18.9mpg driving the way i always do...."spritual"....
Well i decided to give Shell Vpower gas 93oct a chance so last week i filled the tank...i did not change my driving habbits whats so ever..and now i am up to 20.4mpg
Discusss....
Old Nov 8, 2005 | 03:13 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
There are WAY toooooooo many factors to contribute to gas mileage increase or decrease. It is hard to say... but there are some gas brands that peform much better than others. I have always had luck with Amoco Ultimate... I guess now BP.
Old Nov 8, 2005 | 03:38 PM
Nathan Plemons's Avatar
Nathan Plemons
Did you calculate that yourself or did you use the gas mileage readout on your dash?
Did you happen to have a tail wind last week when you ordinarily had a head wind?
Not trying to say that you didn't get an increase, rather that you would really need to qualify it with more data, long term averages mean a lot more than short term.
Old Nov 8, 2005 | 04:11 PM
SledUtah's Avatar
SledUtah
St. Jude Donor '06
Maybe Shell adds acetone
http://forums.corvetteforum.com/show...07&forum_id=34
Sorry, couldn't resist
Old Nov 8, 2005 | 04:16 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Old Nov 8, 2005 | 04:26 PM
Nathan Plemons
I was wondering how long that would take.
Old Nov 8, 2005 | 07:36 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Not long!
Old Nov 8, 2005 | 07:49 PM
JrRifleCoach
Wouldn't it be funny if that was true?
"VPower cleans your combustion chambers and the gf's finger nails"
Old Nov 9, 2005 | 08:10 AM
LT1Vetteguy78
I didn't do anything different then the norm really....just aggressive driving as usual ....its up to 20.5
Old Nov 9, 2005 | 11:23 AM
GKK's Avatar
GKK
My "91" was averaging 18.5 mpg then, I changed the cap and rotor and the mileage went up to 20.3 mpg.
Old Nov 9, 2005 | 11:38 AM
thomastl's Avatar
thomastl
88 conv. 6 speed.
23 mpg from California to Alabama. Average 76 mph 92/93 octane fuel. Whatever brand was along the way.
New rotor, cap, plugs, wires, synthetic Mobile 1, remove and clean injectors, proper air in tires, clean tb, clean iac, gut air pump and remove hoses, TB coolant line bypass, new air filter, clean EGR valve
28 mpg interstate at 76 mph average.
24 mpg town.
Fuel - regular 87 octane - whatever brand is cheap (usually Race Trac)
Obviously going from premium to regular did the trick.
Old Nov 9, 2005 | 12:12 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I'm with kwik.
The change you saw was well within the range of normal variation.
Larry
code5coupe
Old Nov 9, 2005 | 07:38 PM
85 500 horse's Avatar
85 500 horse
I agree with the majority. There are far too many variations that can occur to cause the mileage difference. Passengers in the vehicle, wind speed (for or against), water in the gas, actual octane in the gas, grade the car was driven at, how much uphill or downhill driving, cruise control usage, and a lot more.
You would need to drive to the same places, the same time, in the same weather conditions, etc., numerous times, before you can come to the conclusion that it was the gas that increased your mileage.
Old Nov 9, 2005 | 07:40 PM
the blur's Avatar
the blur
all gas comes from the same distrubutor. there is only 1 distrubutor in each state, except NY where there is 2. even the no name fuel comes from the same place.
Old Nov 9, 2005 | 07:44 PM
Nick 418's Avatar
Nick 418
[QUOTE=thomastl]88 conv. 6 speed.
24 mpg town.
6speed? Didnt the ZF 6 speed come out in 89? Or did you do a swap?
Old Nov 9, 2005 | 08:52 PM
thomastl's Avatar
thomastl
Richmond Gear 6 speed.
4+3 went out on the previous owner and he swapped it rather than trying to rebuild.
Gas comes from one distributor is right but additives are put in depending on the station. Additives and exact fuel octane can vary which will cause small differences in fuel mileage. However, daily driving cannot accurately measure the difference since there are too many variables in daily driving. For example - on the last tank you were stopped by 400 redlights and on the next tank you only got stopped by 350 redlights that would make a difference due to the extra acceleration. Did you climb the same hill to and from the house exactly 50 times on both tanks. Etc.......
Old Nov 9, 2005 | 08:59 PM
Vette73's Avatar
Vette73
LS/MFT
St. Jude Donor '09-'10-'11-'12
My '90 was averaging 22.5 then my "TransAM" daughter took it out for a night and the average had dropped to 16.2 -- wonder how THAT happened?
To Gas mileaged increased
Old Nov 10, 2005 | 04:50 AM
94rick's Avatar
94rick
3rd Gear
Well, she either let her boyfriend drive it or it was sitting parked with the A/C going....
Old Nov 10, 2005 | 07:08 AM
Aquaman92's Avatar
Aquaman92
Do you really want to know?
Old Nov 10, 2005 | 04:33 PM
Midnite 88's Avatar
Midnite 88
Where did you get your information from?
