trans, question
Old Nov 13, 2005 | 10:28 AM
corvettejunkey's Avatar
corvettejunkey
Default trans, question
can anybody telll me what the diffrence is between the 700r4 out of my 85 vette, or a 700r4 out of a camero?
Old Nov 13, 2005 | 12:05 PM
JackDidley's Avatar
JackDidley
Camaro unit will not shift into OD at wide open throttle.
Old Nov 13, 2005 | 12:11 PM
Pete K's Avatar
Pete K
Also, different tail housing, different output shaft, different pump pressure spring, tv spring (I think), valve body, governor, case, servo, torque converter, accumulater springs, etc. This is not to say that a camaro trans will not work. It can bolt in but will have different "character" than a vette trans. You must cut down the output shaft, change tail housing and relocate the speedo drive gear at an absolute minimum. I have a vette trans for sale th c4 sale section. It is a vette trans. Not a converterd trans.
Old Nov 14, 2005 | 03:06 PM
Pete K's Avatar
Pete K
I took an 87 cargo van trans and reworked it to c4 standards. He is very happy with it. It seems the vette cores are selling for $500. That is if you can get them. Now that I learned the tricks, I won't be buying vette cores anymore. Unless they are priced right.
Old Nov 14, 2005 | 04:13 PM
WEH 2000C5's Avatar
WEH 2000C5
Whats the procedure for the van t'mission conversion,what parts are required,any pictures?
Old Nov 14, 2005 | 05:43 PM
Pete K's Avatar
Pete K
I have not figured out how to post pics. At age 38 I am not too computor savy. The trans case is basically the same, as are the major internal components. On the unit I installed a vette servo,vette governor, modified the outputshaft and relocated the speedo gear. Installed the correct tailhousing, b&m shift kit, transgo seperator plate, vette shift linkage lever, etc. The only thing I did not install(per customer) was the wot 4th gear upshift valve. He felt it was not wort doing. He uses the car as a daily driver and a weekend drag car. GM intentionally installed the wot valve in police cars and vettes only. It pounds the 3/4 clutch pack hard and helps kill the trans early. Contemporary Corvette wanted $500 for a core. We bought a $125 junkyard van core and spent another $200 on vette specific parts. Saved him money in the long run. It also saved him a 2 hr drive and fuel/tolls to get it.
Old Nov 14, 2005 | 05:44 PM
Pete K's Avatar
Pete K
To trans, question
