c4 engine trouble
Old Nov 13, 2005 | 11:10 AM
offaxis's Avatar
offaxis
Default c4 engine trouble
Hi
A member of our club has a c4 with major trouble. When the engine temp goes above 105 it starts to missfire amlost to a stall. He has to keep a low idle and feather it to get it around the block.
He hooked up a code checker to the engine and no codes came up.
I think its related to the mass flow sensor but he wants to be sure because of $$$$$$
Thanks,
Jeff
Old Nov 13, 2005 | 11:15 AM
FD2BLK's Avatar
FD2BLK
Sounds like the O2 is either bad or doesn't like what it is seeing, ie vacume or exhaust leak. It sounds as if as soon as the car goes into closed loop it starts to miss.
