tire sizes
Old Nov 14, 2005 | 12:32 PM
Red_Vette_93's Avatar
Red_Vette_93
Default tire sizes
I had this info but can't find it...I want to put 18x9.5 on all 4 corners, what's the biggest tire I can fit in the front & back.
Old Nov 14, 2005 | 10:28 PM
MYCoupe's Avatar
MYCoupe
275/35/18 or 285/35/18. You can also do the 275s up front and the 285s out back, but then you can't rotate them.
Old Nov 15, 2005 | 10:21 AM
Red_Vette_93
can I put 10 inch rims on the back? would that be the biggest I could put on..
I found out I could go up to 11 in the back if I want, but another concern is how the car tracks on the road with bigger tires.
anyone here have problems with the handling after changing tire sizes, I don't want to be fighting the car to drive it.
Old Nov 15, 2005 | 10:24 PM
MYCoupe's Avatar
MYCoupe
I have 18x10.5" stock Z06 wheels in the back with 295/35/18 tires. Car handles great so I wouldn't worry about wider tires in the back.
Old Nov 16, 2005 | 02:10 AM
BAM92's Avatar
BAM92
Worry more about wider tires in front. I have 285/30's on vette and 285/35 on Trans Am and they tend to track grooves in the road on the highway. I have 335's and 315's on the rear respectively without a problem. I am going to go to 275/35's on the front of both cars soon.
Old Nov 16, 2005 | 10:46 AM
Red_Vette_93
what are your wheel sizes?
Old Nov 16, 2005 | 10:56 AM
Z51JEFF's Avatar
Z51JEFF
Ive got 275-35 18 on a 10 inch wheel,wish the tires were a little taller.I had the wheels made with 1/2 inch extra negative offset and have no problems with rubbing.
Old Nov 16, 2005 | 02:03 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I run 275's in front and 315's out back on 9.5 and 11" rims, respectively...no problems but the fronts do track the grooves a bit...if you don't drive with one finger on the steering wheel you'll be fine...
To tire sizes
