Does my engine need to be cleaned?
Dan, hope you don't mind, but I hosted this smaller image of the drivers side of your engine as well...
Nice prop rod, by the way
If you want to clean your engine, go for it. Like others have said though, I'd do it yourself. Likewise with the detail work to the interior/exterior. I'd save the $260 they want to detail it for mods. That, and personally, I've never known anybody that can detail a car better than I can do it myself.
Start with a wash with Dawn dish soap... if you really want to go crazy, get a clay bar get and follow up with that... then get yourself a decent quality polish and apply it. If you want recommendations for types of cleaners for different parts of the car, just ask.
As for the motor.... I would use Simple Green like a few other people have said. It's a great de-greaser. Put a plastic bag over your distributor and around your alternator. Avoid spraying the hose directly onto your throttle bodies. Cover them with plastic if your really going to use a lot of hose pressure to get the top of the intake manifold. But you shouldn't need too... Soak the whole thing down in Simple Green and let it sit for 15 minutes or so, then use a light hose pressure for rinsing and rub stubborn areas with a rag.
I'd get some carb cleaner and work on those throttle bodies with that. Never hurts to clean those out every once and awhile. Spray all around the tops and sparay some down into the throats as well and take your finger down there to scrub a bit...
correct except spelled with a 'c' crankcase. (of course I've always referred to them as pollution control valve LOL)
It plugs into your valve cover and appears to be pretty nasty looking in your picture.
I use the free photobucket with out problems!
However, I clean my engine using simple green, a brush, scotch brite pad and then I drive down to the local highpressure coin car wash to blast away the grime.
My opti likes it JUST FINE!
Mike
Annd... The picture i posted is of the Passenger side(without the air cleaner) the one with the aircleaner is the drivers side.
The PVC is on the drivers side and i changed it a few months ago.
-Dan
