Front lower panels
Old Nov 18, 2005 | 09:12 PM
C4STL's Avatar
C4STL
Default Front lower panels
My '89 front lower panels , ( the ones right in front of door with gills) arent perfectly flush with bottom area where meets the body . Not real bad but just not perfectly square in the middle, bulges a little. Is this normal? The main body area where plastic panel meets is straight.
Old Nov 18, 2005 | 09:46 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
No... they should be flush... but it is only a series of a couple of screws and movement to line the fender up.
