90 airbag reset??
I purchased the MidAmerica piece, plus Gordon Killebrew's plugs. All I really needed was a piece of wire, one short and one long, which I had laying in my shop.
Jay Meeks did a complete article on the codes, plus clearing the codes.
The INFL REST and the seat belt light should both come on at the same time. The passenger side sensor does not get as much water on it as the drivers side. It can rust though. There is also a connector under the carpet, passenger side, right at top lip of carpet under the dash.
The yellow cable from the RH sensor is plugged in and going to dash area. Pull this apart and spray electronic cleaner on the connections.
From the Corvette forum members helping me, I pulled the codes, did the fix and cleared the codes.
If you want the Jay Meeks article, I may be able to send it to you.
Check Corvette Fever's web site. There will be a link there for this subject. If you can't find, let me know, I will get it to you.
Boatman
www.gordonkillebrew.com
They are called: Fault Code Diagnostic Grounding Plugs
The plugs are a nice set up. Reason I used a piece of wire to get codes and clear codes, is that one of the forum members called me up, had me get under the dash and walked me thru using his method, which was one short piece of wire to run from I think, K to N, and a longer piece to run from one of the receptors to the seat frame, for counting off in seconds the amount of time to ground and clear the code.
I kept the Mid America piece and Gordon's plugs.
Boatman
90 Vette. It was the opposite for me, as my drivers side was rust on the mount. This Z only has 16K miles on it, garaged it's entire life. Other C4 owners told me that the drivers side gets it from car washing, and the passenger side gets it from the AC exchanger condensation dripping on that side. When I looked at the passenger side on my Z, it was like new.
Why would the washer bottle leak? I was not too enthused about taking it out, looking like I had to remove the blower motor to get to it.
Other guys I talked to wrenched it out, but took a lot of time.
Picture attached of the passenger sensor and picture of the drivers side off and re-mounted.
The yellow cable on the passenger side goes thru the firewall and to bottom of carpet inside, hooking up with looks like gold pin plug, female and male.
I did not have success clearing the code until I sprayed electronic cleaner in that connector. It is possibe the drivers side sensor was fine, and my problem was the cable and plugs only.
I think it was pulling a code 26, not sure. That is the passenger side.
Boatman
I cannot comment on re-use. Should be fine.
Boatman
