C4 Ground Clearance?
Old Nov 22, 2005 | 10:25 AM
VQT88Vette's Avatar
VQT88Vette
Default C4 Ground Clearance?
Does anyone know the ground clearance of the C4? 1988 in particular.
Is it more than 4.75"? I wonder if this mid rise lift is low enough.
http://www.americanautomotiveequipme...1668/index.htm
Thanks,
Old Nov 22, 2005 | 10:44 AM
tnt-sportfishing's Avatar
tnt-sportfishing
Cut some 2 X 10's or 12's in one foot sections for all 4 wheels. Drive on top of the for an additional 1 3/4". Will give you plenty of room.
Old Nov 22, 2005 | 10:48 AM
VQT88Vette's Avatar
VQT88Vette
I was hoping that it clear so I can park the car over it every day.
Old Nov 22, 2005 | 11:37 AM
Ericsvette's Avatar
Ericsvette
The minimum ground clearance for the '88 Vette according to the Corvette Action Center is 4.7".
Old Nov 22, 2005 | 11:56 AM
VQT88Vette's Avatar
VQT88Vette
Thanks,
Its going to be rough pull the car in evry night with the lift then.
Old Nov 22, 2005 | 07:41 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
It might be the picture, but that lift looks to be a little light/fragile. From the looks of it, I`m not sure I would get under it.
To C4 Ground Clearance?
