Windshield Washer Fluid
Old Nov 25, 2005 | 04:57 PM
90LongIslandVette's Avatar
90LongIslandVette
3rd Gear
Default Windshield Washer Fluid
I usually search old posts for my problems but I can't seem to find an answer to this one. I have 90 coupe and the windshield washer fluid does not come out. Now I WAS smart enough to check if there was any in the well and there was. I'm not even sure where jets are.....maybe on the wiper blades themselves? The miserable Northeast winter is coming fast and furious so I better get rolling on this one. Any ideas???
Old Nov 25, 2005 | 05:28 PM
rick96cevette's Avatar
rick96cevette
Just a thought....check fuses. Do you hear the pump running when trying to squirt the washer fluid?
Old Nov 25, 2005 | 05:33 PM
96_LT4_FE1's Avatar
96_LT4_FE1
This Oct. post was the best I could find, and there ain't much there.
If a better idea doesn't come up, I suggest listening for the pump to run.
I could be wrong, but I'd check the reservoir itself to see if the pump is mounted under it. If it was ever run dry, they die fast with no fluid(like a fuel pump). If the pump is not there, it could be in-line(follow the black rubber hose), or sometimes they are mounted right in the wiper motor assembly(even the electric pumps).
If you jumper 12 volts to the pump, it should run.
Also, if you can, make sure to get a "quality" replacement. I've replaced alot of pumps in my day, If they are under $15, they make me nervous.
Hopefully that is all it is, it is also possible it could just be a fuse or the switch in the column.
Sorry I can't be more specific, but I'm a vette Noob yet. However, living in saltville, I know the need for windshield washers. I had to build a system from scratch for my CJ, except for the in-cab control.
HTH, »keith
Old Nov 25, 2005 | 06:12 PM
HOOBS's Avatar
HOOBS
Shoot some low pressure air through the lines.....That is if the pump still works
Old Nov 25, 2005 | 08:23 PM
czissman's Avatar
czissman
Have you checked the routing of the tubes that connect the nozzles to the resevouir? I had this problem and it turned at that one of the rubber hoses had disengaged. Plugged it back in and all was cool.
Old Feb 16, 2006 | 01:39 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
It could also be your windshield washer check valve.
Old Feb 16, 2006 | 06:09 PM
Aardwolf's Avatar
Aardwolf
I dunno about anyone else but it took me reading the owners manual after a month of the sprayer not working to figure out how to operate my sprayer! You have to push the butten inward and then hold it downward in the slot. It's kind of tricky! When I first got the car I thought the pump was shot, but nah it was operator error. Are you pushing the switch right?
Old Feb 16, 2006 | 07:48 PM
c4cruiser's Avatar
c4cruiser
Some cheap washer fluids are soap and that causes the screeni n the pickup tube to clog. You can have a brand new pump, no restrictions in the hoses or the nozzles, but if the fluid can't be sucked into the pump, they just are not gonna work.
The washer tank assembly is not that hard to remove and it would be worth pulling it and give everything a good cleaning. Refill with 20/20 premix and you should be OK. Don't spend extra money on the AC Delco fluid as it just does not do a good job compared to the 20/20 stuff.
Old Feb 16, 2006 | 09:31 PM
CJB's Avatar
CJB
Also check the actual small hose located on the tank bottom for secure attachment. Have someone look at the fender well underneath when you activate the washer for run off.
To Windshield Washer Fluid
