Big Block swap?
but let me tell you what i know.... Big Blocks cost a hell of a lot more money to build ub than your traditional small block... Plus not to mention they are alot heavier. Which is going to throw your handling way off so forget about handling if you choose to go that route... Just build a stroker motor or a blower motor and be done with it... You can put out simillar numbers with a small block as you can with a big block for less money. Big Blocks are just for bragging rights... It sounds more impressive.
My first question is, why? If you're after performance, there's no reason not to stick with what you have re: the block. With all the FI/stroker formulas and kits, I can't see any reason to not use the stock block.
In fact, I know at least one guy who swapped out his 454 smogger out of his C3 in favor of a hard-tuned 327, along with the front suspension. It was simply cheaper and easier to build a high-po small block than to re-invent the wheel with the low-comp smogger big-block.
You need custom headers and that is probably your bigest problem.
You probably want to use the extra stiff 1984 Z51 front fiberglass spring.
Moral to the story? Have fun with the big block and if you are ever near Charlotte I want a ride!!
A second moral is that I'm also into sport bikes and for $10k I can get a bike that can do things a $100k car can't... My second car's a Yamaha R1...
Might check with ski_dwn_it
I was thinking much the same thing...
Larry
code5coupe
Actually the plugs are much easier to get to on the big block since they are between the header pipes as opposed to under them on the small block.
The motor ima build be it small or big block it def wont be streetable, well pass emissions, ima still drive ti on the street, haha
and i only have this past years corvette fever, any1 gotthis mag i can buy from ya?
