New 2 Here
Old Nov 28, 2005 | 10:47 PM
JnC96CE's Avatar
JnC96CE
Default New 2 Here
Im Joe
My wife is Christy
My brother and my sister have owned vettes in the past that I have driven.
I have never owned one myself untill now.
We came across a 1996 CE convertible.
It has the beige interior in it.
LT1 with automatic.
Just over 24000 miles on it.
The Vette is just like new, with the original tires on it.
I probably will not post much but am sure that I will learn about the car quite a bit on here. (Like how to put the top down)
More stuff later as I learn my way around
Old Nov 28, 2005 | 10:57 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Welcome!
Old Nov 28, 2005 | 11:10 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Hello Joe. Hello Christy. That must be one rare Collector Edition as the only factory authorized interior colors were black, light gray and red. Welcome to the madness!
Old Nov 29, 2005 | 12:14 AM
EPiC Vette's Avatar
EPiC Vette
Get new tires and drive it like you stole it!
Welcome!
-Eric
Old Nov 29, 2005 | 12:18 AM
rws.1's Avatar
rws.1
Welcome... you will find in friendly and helpful in here and everyone wants pics .... especially with the top down .....
Old Nov 29, 2005 | 12:42 AM
Ericsvette's Avatar
Ericsvette
Welcome to the forum, and congratulations on your new Vette.
Old Nov 29, 2005 | 12:48 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Hi Joe, Welcome.
Read the owners manual cover to cover. THat will help alot. Especially when it comes to the E brake. Don't want you having to get towed home.
Remember to wave!
Old Nov 29, 2005 | 12:54 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Welcome Joe & Christy. Your CE sounds like a sweetheart. That baby's just getting broken in, you have many pleasurable miles ahead of you!
Old Nov 29, 2005 | 06:15 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
welcome aboard
Old Nov 29, 2005 | 06:50 AM
joe3906's Avatar
joe3906
Congrats! You and your wife got your Xmas gifts early. Best of luck with your new toy. Welcome to the obsession.
Joe B.
Old Nov 29, 2005 | 07:25 AM
Aquaman92's Avatar
Aquaman92
welcome to the form sounds like a nice vert.
Old Nov 29, 2005 | 10:29 AM
rick lambert's Avatar
rick lambert
welcome-sounds like a nice one, but I have to worn you,
once you buy a vette-it's in your blood
Old Nov 29, 2005 | 10:55 AM
Cozmo's Avatar
Cozmo
CentralTX Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Welcome Joe and Christy. I agree with the suggestion to get new tires. Those original tires are probably hard as rocks by now.
Old Nov 29, 2005 | 11:18 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Nice choice of Corvettes!! Welcome to the forum. If you are like most of us, you'll spend far more time than you should on it...reading and posting.
The longer you are here, the more you'll post.
PS You didn't have to tell us it was an automatic, we already knew that. Can you guess how we knew?? (that's a trivia question)
Larry
code5coupe
Old Nov 29, 2005 | 01:41 PM
SJW's Avatar
SJW
Welcome to the Corvette Brother/Sisterhood, and Congrats!!! You have just acquired a great toy. The first two rules you need to know are:
1. Always wave!
2. Always stop to offer help.
As others have suggested, read your owner's manual cover-to-cover. If you intend to spend any time under the hood of this car, I highly recommend you get a copy of the Factory Service Manuals for your '96. They're worth their weight in gold. Check with Helm, Inc (who publishes them for GM), and/or E-Bay. If you shop on E-Bay, make sure you get a set with the red covers (others are preliminary editions, and will be less complete and accurate than the final, red-cover version).
If you don't have the owner's manual, get one of those too. Until then, to drop the top:
1. Fully release both of the locks above the sun visors. Fold the sun visors down out of the way.
2. Open both doors, or lower both windows.
3. Pull loose the two inner liner flaps that are Velcro-secured at the B-pillar location (just behind the rear vertical edge of each side window).
4. Release the top from the deck at the rear. There should be a release handle under the deck lid behind the driver's seat headrest.
5. Lift the rear edge of the convertible top as high as it will go, and hold it up there.
6. Release the latches on the deck lid (there should be a release button under the deck lid, not too far away from the other handle you just pulled).
7. Raise the deck lid to its fully upright position. Take care as you raise it to ensure that the leading edges of the deck lid don't contact the weatherstripping on the raised convertible top, or it can damage the weatherstrip.
8. Check to be sure that there's nothing in the storage compartment that will interfere with the top as it stows away in there. If in doubt, remove everything to be sure you have the necessary clearance back there.
9. Lower the rear edge of the convertible top back down to its normal resting position. It should now be hanging over the opening.
10. Gently lift the front end of the convertible top, and continue rearward until the entire top has folded and dropped behind the seats.
11. Swing the two latches (at the front edge of the convertible top) back to their normal position (as if they were latching to the windshield frame).
12. Gently push down on the top on both sides, to make sure it's settled into the storage cavity.
13. Gently close the deck lid over the stowed top. Press down on each side to fully latch the deck lid (two clicks per side).
14. Go cruise in a Really Cool Topless Corvette!
Raising the top back up is basically the reverse of the above procedure, but you'll also have to press down on the top above each of the two rear latches to latch the rear edge of the top to the deck lid. This is done as the last step in the procedure.
Be sure to send us some pix, and add some useful info to your profile (details about the car, where you live, etc) so that we're better able to help you out when you have questions in the future.
Be well,
SJW
Originally Posted by JnC96CE
Im Joe
My wife is Christy
LT1 with automatic.
Old Nov 29, 2005 | 01:46 PM
89sleeper's Avatar
89sleeper
From: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
Welcome to the C4 family
Old Nov 29, 2005 | 02:06 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
Welcome!
To New 2 Here
Old Nov 29, 2005 | 07:13 PM
JnC96CE's Avatar
JnC96CE
Thanks everybody.
I don't know how you knew it was an automatic.
I did print off the top up and down instructions(thanks)
And I don't know why it has the beige colored interior either.
I put a couple of pictures in the 96CE portion. Maybe you all can find them there. Its been rainy out since we got the CE, so the pictures are from the garage.
Your right about the tires, they have got some tread but do show signs of cracks here and there.
Oh yeah, it did come with an owners manual and some reciepts from the first half of its life.
Old Nov 29, 2005 | 08:48 PM
rick96cevette's Avatar
rick96cevette
Thanks everybody.
Welcome to the obsession!
Old Nov 29, 2005 | 08:52 PM
redvette6spd's Avatar
redvette6spd
Welcome It shouldn't take you to long to figure out the automatic thing
