Couple Problematic Questions
Old Dec 1, 2005 | 04:04 PM
wgc_3's Avatar
wgc_3
Default Couple Problematic Questions
1) How do you turn off the check oil light?
2) On a 91 Corvette you can not pull codes I know there is something you can do with a paper clip to pull the codes from the ECM, does anyone know what it is?
Thanks,
Bill
'91 Vette
Old Dec 1, 2005 | 06:36 PM
Red Dwarf's Avatar
Red Dwarf
Go here for code info.......http://www.corvettebuyers.com/c4vettes/
Use this for oil reset. I believe yours will be range instead of gauges?
http://forums.corvetteforum.com/show...et&forum_id=48
