SLP Performance Pac
Old Dec 1, 2005 | 10:36 PM
TOO_HOTTVETTE's Avatar
TOO_HOTTVETTE
Default SLP Performance Pac
WOW LT1 makes LT4 power with SLP performance Pac!!! Vette magazine did a "test" These are the dyno #'s
Air foil (the call it a 'booster') = 30 more cfm (not dynoed)
Claw air filter system= 8.3 hp (with 'booster')
Cat back exhaust= 7.7 hp
1.6 roller rockers= 11.4 hp
That's 27hp gain at the rear wheels!!!!
This just don't seem right to me, They claim Stock '95 Vette 6 speed made 277.1 hp/264tq at the wheels (319hp/304tq at crank)before and 304.5hp/292.1tq at the wheels (13% correction factor for drive train loss= 350hp at the crank) after.
What do you guys think?
Old Dec 1, 2005 | 10:46 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I'll tell you what I think, SLP hooked me up with those exact parts and I ended up with 350 hp, they never told me where, so I have to assume at the crank.
They used my car to test these products. I haven't had it at the track yet to verify any imporvements.
They also dynoed my car stock and it made 318(again assuming crank HP).
My car with a Corsa dynoed at 285 at the wheels.
Old Dec 2, 2005 | 04:42 AM
locobob's Avatar
locobob
What issue is this in? Looked online but didn't find anything.
Old Dec 2, 2005 | 07:16 AM
Mr Mojo's Avatar
Mr Mojo
I'm going to have to take a look at that magazine, that just may be my car they are talking about.
It was down on power due to the throttlebody not opening all the way. You got me wondering now.
Old Dec 2, 2005 | 09:35 AM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Now that would be cool if it was yours. If you find it online give us the link. I would like to read it too.
Old Dec 2, 2005 | 11:22 AM
C4DC's Avatar
C4DC
St. Jude Donor '06
I would say nearly all the hp is a result of the rockers...
Old Dec 2, 2005 | 02:11 PM
Rapid Fred's Avatar
Rapid Fred
Why would you say that -- it appears as though they dyno'd these separately. I need to see that article.
I had posted some questions re bolt-ons on the Tech/performance section and the consensus was cat-back, SLP, etc. don't help. Problem was, most of the comments were not supported by data. What little test data I could find, like dyno results, suggests you can get 10-20 HP out of K&N cut lid (or claw) and a cat back. And yet, few believe it.
Is it because those who do the bolt ons and see no improvement after testing don't want to share the results???
Old Dec 2, 2005 | 03:23 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Frank did you have the cut lid with K&N before and SLP claw now??
Typically you can expect around 10chp from the intake mod and 10-15chp from the 1.6:1 RRs. A cat-back change usually brings that sort of gain, so the SLP claim sounds about right.
Old Dec 2, 2005 | 06:13 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
Well, my LT4 with Corsa and cut lid/K&N put 298 corrected to the wheels. Seems from my time here on the forum, the filter box mods do little (~3hp) especially on the dyno where there is no ram air effect. The Lt exhaust seems to flow pretty well and I don't think mine added much if any hp, I got it for the sound/looks. Maybe a more performance minded exhaust (B&B, Power effects, Flowmaster, SLP, etc.) may add more than the Corsa at the expense of spl. Being as how my car puts out around 300 rwhp stock and mine has run the 1/4 in 13.0 at 107, I think it is healthy. I don't put much stock in exaggerated filter and exhaust claims for near stock setups which leaves the rockers which change the brains of the way the engine operates the same way a cam does. Hopefully the SLP stuff does more than the others, I will add it to my wish list. Now I'd like the hot cam and LT headers which seem to add 30-40 rwhp from what Iv'e seen here. I'm intersted to see a dyno run if Mojo does one... :pop:
Old Dec 2, 2005 | 06:42 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
. I don't put much stock in exaggerated filter and exhaust claims for near stock setups which leaves the rockers which change the brains of the way the engine operates the same way a cam does. :
I need some basic education of you don't mind. I thought that the rockers "simply" reduce friction and thus allow more HP to make it's way from the engine to the rear wheels. How do the rockers alone (without a different cam) change the brains of the way the engine operates?
Thanks Peabody
Old Dec 2, 2005 | 07:25 PM
FELNGR8's Avatar
FELNGR8
That is your car, Frank. It is pictured on the dyno on page 60 of the February issue of Vette magazine.
This demonstrates what flat-*** flogging an LT1 will do for the engine. 277 hp to the wheels before they added any parts. Your car has always been strong, now the C5 guys have to fear your street car as well as the strip car. WooHoo!
How many miles on it now? Amazing.
Old Dec 2, 2005 | 07:29 PM
FELNGR8's Avatar
FELNGR8
The dyno run is in the Feb Vette magazine. That's Mojo's car they used. Check out the red over red car with black GS wheels on page 60. It has always been a strong car, how many stock LT1 6 speed cars do you know that have turned in the 12s?
Old Dec 2, 2005 | 07:31 PM
FELNGR8's Avatar
FELNGR8
Thanks Peabody
The 1.6 roller rockers increase total lift as well as acceleration rates at valve opening and closing. They are effective even with the LT1 stock cam, and really effective with the LT4 hotcam.
Old Dec 3, 2005 | 12:07 AM
Mr Mojo's Avatar
Mr Mojo
Thanks Chuck, I'll have to check it out, hell I might even have to buy the issue!
At 277 the car was actually down on power, could be because they took the Corsa off and put the stock back on. I can't tell you how many trips I made to SLP bringing them different parts. I was hoping to run the car at SLP day, but it was cancelled.
The car was strong before and now it is stronger. 133,000 miles on it.
Old Dec 3, 2005 | 12:24 AM
C4DC's Avatar
C4DC
St. Jude Donor '06
The stockers are 1.5 ratio, correct?
Old Dec 3, 2005 | 11:57 AM
FELNGR8's Avatar
FELNGR8
Correct. And the stockers don't have roller bearings at the pivot point of the stud.
SLP emphasized changes that are truly bolt-on that anyone can do. Swapping the cam or valve springs isn't something just anyone can do, but putting on just the 1.6 roller rockers anyone can handle in their garage.
Old Dec 3, 2005 | 12:00 PM
Admrl94's Avatar
Admrl94
Really? Thought it was complicated. I would love to be educated on this!
Old Dec 3, 2005 | 01:45 PM
FELNGR8's Avatar
FELNGR8
You have to adjust them afterwards but if you can't do that take it to a tuner shop. You can adjust them initially just by turning over the motor by hand, finding the closed position on each valve, adjusting it to loose, taking up the slack on the pushrod, then turning down the rocker bolt the correct amount.
Replacing valve springs I don't see how you can do it without removing the head to check the specs of height and seat pressure. Replacing the cam is a bitch of a job on these cars with the motor in the car.
The rocker set comes with an EASY button.
To SLP Performance Pac
