'91 L98 engine lift Points?
Old Dec 4, 2005 | 12:45 PM
jomor's Avatar
jomor
Default '91 L98 engine lift Points?
Can anyone tell me the engine removal lift points for a 91 L98 with aluminum heads? The GM shop manual has no illustration or info on this. The old 350 had lift brackets on opposing corners of the intake manifold.
Should I use front accesssory bolt holes and rear holes on the ends of the head?
Old Dec 4, 2005 | 12:47 PM
89sleeper's Avatar
89sleeper
From: The land of 10,000 lakes ,Minnesota 89 coupe 6speed with 383 and 89 roadster 6speed bonestock with XXX low miles
A strong strap around the intake plentum works
Old Dec 4, 2005 | 08:05 PM
Trog's Avatar
Trog
I pulled my heads on my 90 first, then a load level between 4 head bolts (2 front 2 rear) Made things very easy to get in & out that way.
To '91 L98 engine lift Points?
