Where does the Engine Temp Display get its info from?
Old Dec 4, 2005 | 04:00 PM
Big Willy's Avatar
Big Willy
Default Where does the Engine Temp Display get its info from?
I'm sure the ECM is involved in the process but what I really want to know is What sensor tells the ECM what temperature to display on my dash?
Old Dec 4, 2005 | 04:06 PM
mseven's Avatar
mseven
Water temp. comes from the CTS/coolant temperature sensor, located at the front of the intake manifold
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
The engine temp sensor gives the info to the computer and the readout gets it from that. The gauge has a sending unit so the readings are separate from the readout.
Old Dec 4, 2005 | 04:16 PM
aboatguy's Avatar
aboatguy
On a 1995 input from the Engine Coolant Temperature Sensor (ECT) is what provides the tempurature displayed on the analog guage
Old Dec 4, 2005 | 05:29 PM
96GS#007's Avatar
96GS#007
Better re-read the manual
The digital temp display originates with the ECT sensor. On an LT1/4 this sensor is located in the water pump. The analog gauge receives its input from the sending unit located in the cylinder head. On an LT1/4, the sending unit is in the passenger side cylinder head.
Old Dec 4, 2005 | 05:34 PM
Mo_Bandy's Avatar
Mo_Bandy
Mo
Old Dec 4, 2005 | 06:36 PM
aboatguy's Avatar
aboatguy
If you say so, however, my book (Helms page 6B-6) had the following paragraph which led me to believe its the ECT
"ENGINE COOLANT TEMPERATURE (ECT) SENSOR" The gage coolant temperature is a variable resistance device. The resistance of the sensor will determine the position of the coolant gage. As the temperature increases , the sensor resistance decreases allowing more current to flow through the gage causing a higher temperature reading.
Notice it says position of the gage and not temp read out!!!
Is this another HELMS mistake?
Mike
Old Dec 4, 2005 | 07:04 PM
Corvette Kid
Mike
I don't know but when the sender in the head no workied, my analog gauge no workied either! But I still had the readout until I got it fixed. They may be calling the one in the head a sensor whereas I would call it a sender. Either way, their description how it works is correct.
Old Dec 4, 2005 | 07:15 PM
aboatguy's Avatar
aboatguy
when I was started my first post no one had posted yet. I was reading the Helm's looking for the answer and then posted. I don't know whether the ECT is in the head or not, however, I know that the sensor that I broke during my header install affected my analog guage. So I am agreeing with you Chris.
Mike
Old Dec 4, 2005 | 07:21 PM
mseven's Avatar
mseven
You are both in essence saying the same thing but............the guys car is an 89
Old Dec 4, 2005 | 08:53 PM
SunCr's Avatar
SunCr
'89 gets it's gage readout from the sender in the right head between 6 & 8. It's a thermistor in that resistance decreases as it warms up. Disconnect and the gage should read LO. Ground the lead against the block and it should show about 300 and the red warning light should come on. Neither test speaks to the accuracy of the sender, but will verify the integrity of the wire and the display. Best to compare it's read with the Coolant Temp Sensor signal (located on the intake below the throttle body). You do that with a scanner and they should be within a couple of degrees of the other. Otherwise, if you think the gage sender is bad, simply replace it. They're fairly inexpensive and NAPA stocks it. Just be sure to buy a gallon of coolant too.
Old Dec 5, 2005 | 07:57 PM
Big Willy's Avatar
Big Willy
I disconnected the sensor in the right head and the display went to LO, so I see where the display reading come from. SO, What is the purpose of the Coolant Temp Sensor below the throttle body ('89 Coupe)?
Old Dec 5, 2005 | 08:40 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Thats the one that communicates with the ECM to activate fans and if memory serves me it also has to do with open and closed loops.
Old Dec 5, 2005 | 08:57 PM
Vette73's Avatar
Vette73
LS/MFT
St. Jude Donor '09-'10-'11-'12
Took 13 posts but you guys got it. Would have saved some time if Big ***** had said he had a '89 to begin with.
Old Dec 6, 2005 | 09:36 PM
Big Willy's Avatar
Big Willy
Oh yea....Sorry about that.
To Where does the Engine Temp Display get its info from?
